Old 05-27-2014, 08:26 PM   #1
Happy Member
GT4six's Avatar
Tiger Trak on GT
just got the Tiger Trak from blue ox today. I have a question and seeking your wisdom & experience,
the instructions & parts list calls out for the 2 bolts that go on the bushings for the bar to be torqued at 257 lbs, really?
my torque wrench only goes to 150lbs.....hmm guess I need to buy a heavy duty one.
also how long did it take you?
thanks.....
BTW- thanks for taking easy on DW & her Diaper table conversation
Me, DW and final score...
2 Girls-2 Boys
The lazy nanie K9
2013 FR GT 351DFS
GT4six is offline   Reply With Quote
Old 05-28-2014, 07:30 AM   #2
Everyone will tell you to use a torque wrench as it's the correct way to do it.
I also didn't have a torque wrench that big, so I used my calibrated arms along with red Loctite.
Mine took longer to install because the bar was too long to fit between the pumpkin and frame bracket. Had to cut some of it off to make it fit. Don't forget to check all bolts after a few thousand miles.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-28-2014, 08:53 AM   #3
Happy Member
GT4six's Avatar
Thanks Al,
OK- I just wanted to bounce it off someone else that has done it...sp I'll do the same thing
I didn't check the lenthg of the bar....I'll do that this afternoon. I did check all the brackets and hardware since that was the problem last time.
How long did it take you?
2 Girls-2 Boys
The lazy nanie K9
2013 FR GT 351DFS
Old 05-28-2014, 08:58 AM   #4
The install is pretty quick once you figure out how the brackets go. I raised the rear end a little bit for more room with my creeper and grabbed my impact gun. I'd say it took about 30 minutes after figuring out the brackets and correct sockets. Don't forget to do the rear CHF while you are down there...if you haven't already done it.
Old 05-28-2014, 09:18 AM   #5
Happy Member
GT4six's Avatar
Great Info...I appreciatte it.
Yes, I did the CHF about a month ago...I'm gonna attempt to tget this done this evening afterwork.
How much of a difference did you notice after installing the T-Trak?
2 Girls-2 Boys
The lazy nanie K9
2013 FR GT 351DFS
Old 05-28-2014, 09:45 AM   #6
I have to be honest in saying that not as much as I wanted to see. It reduced the tail end roll a bit, but so far the best improvements have been CHF and tire pressure. I still have steering stab and alignment to do.
Old 05-28-2014, 09:12 PM   #7
Happy Member
GT4six's Avatar
Yeah me too...I think those too you mentioned will be the last two for me for now and go back to Mod amenities in the inside (I,e audio sys. DVD, subwoofer, Surge protector)...
holly smokes I need another job to pay for this.!
2 Girls-2 Boys
The lazy nanie K9
2013 FR GT 351DFS
