Old 10-07-2009, 12:23 PM   #11
NWJeeper's Avatar
Originally Posted by khager View Post
Yes keep an eye on your tires, and if you suspect the alignment is off have it checked. I just bought a new Georgetown in May 09. Drove it home and took a few short trips and had about 1300 miles on it. Checked the air several times always at 80 psi. Then I left for a one month trip to CA, when I got back as I was checking the tires I noticed the left front had about half the tread as the others, which I verified with calipers. This is at 5800 miles now. The right front had some wear on the inside edge. Took it to an alignment shop and the toe was off quite a bit, camber also off. I went ahead and swapped the LF with the new spare I had bought 2 months earlier for $330. After further research I found this is quite common. Lesson learned even with a brand new rig, have the alignment checked. $150 well spent. Dealer said no way FR will pay for alignment with 5800 miles on rig, but it takes a while to notice the wear, although I wasn't checking for wear, I just noticed it because it became obvious.
Also happend to us, didn't notice until to late and just spent close to $900 on new tires, took RV home and parked it in the garage, won't drive it again until I can afford the front end alignment. Also know that for large Class A RVs you can't just take it to any shop for an alignment, they have to be set up for large rigs.
Ed & Wendy
www.nwjeepn.com
Old 10-07-2009, 01:43 PM   #12
TulsaSteve's Avatar
80 lbs?
My 370XL specifies 90lbs. I'm on the 22.5 rims, so that may be the difference.
TulsaSteve is offline   Reply With Quote
Old 10-07-2009, 05:55 PM   #13
NWJeeper's Avatar
Originally Posted by TulsaSteve View Post
80 lbs?
Pressure should be adjusted due to the weight of the rig. Assuming a proper front end alignment tire pressure being incorrect will cause uneven wear either in the middle of the tire (over inflated) or outsides of the tire (under inflated) Wear such as we had was from the inside of the tire inward on both indicating that the camber of the suspension is set wrong. Many find that with a light load reducing tire pressure results in a smoother ride. The pressure recommendation on the side of the tire is the maximum inflation for a fully loaded rig.
Since FR will only address alignment issues on their coaches for the first 90 days as we found out, I would highly suggest that a owner of a new coach should have the front end alignment checked by a competent shop immediately. Consider it a cheaper insurance policy against a $900 tire bill a year down the road.
Ed & Wendy
www.nwjeepn.com
Old 10-07-2009, 09:24 PM   #14
will do
Dix and SB,
2 chihuahuas (Scout and Katie dog)
and 1 Cat - Harper Lee
Altoona Pa.
new at RVing but
Lovin our Georgetown 378
Lots to learn
landofdixie is offline   Reply With Quote
Old 10-13-2009, 07:52 PM   #15
Just took delivery of my 2010 378 and have travelled 1500 miles in the last 2 weeks. This info is good to know. I think I better check mine out.
Snowbird is offline   Reply With Quote
Old 10-13-2009, 08:13 PM   #16
NWJeeper's Avatar
Snowbird,
A friend of ours recently returned home from his vacation and related a conversation he had with the camper next to him. Seems this gentleman has owned 5 new RVs in 3 years and he says that the first stop for him is an alignment shop to have the front end re-aligned. Since most manufactureres will only cover the cost in the first 90 days he submits a claim to them right away for the cost. Says he has never had a manufacturer refuse to pay yet. Wished I had known this when our Georgetown was new. Might have saved me $900
Congrats on the new rig too, enjoy it as we have ours.
Ed & Wendy
www.nwjeepn.com
Old 10-23-2009, 11:23 PM   #17
The 378XL is great Motorhome. My wife and I love ours, it's 2008
Replaceed ans added a few things already. Added spray hose in toilet area.
Added 22" LCD TV COMBO in bedroom, the Weastinghouse 19" was not easy to watch laying in bed. My wife likes to have air flow across her while sleeping, so I added a 12V fan. Also put lights in toilet area on light switch and the list goes on.
None of this has anything to do with yours, it's just a friendly note to let you know that I know alot about the 378 XL and if you ever have a problem or want to know how something works I can probably help. There is still a lot I'm learning and a lot I don't know, in which case I just ask all the many brilliant minds here at this wonderful website for us.
Congradulation on your new Purchase and may you be as Happy with yours as we are with ours.
Joe & Jeannette
JDickson is offline   Reply With Quote
Old 12-29-2009, 08:33 PM   #18
JDickson,
Thanks for the info about the light in the toliet room and the tv in the bedroom. The wife and I just bought our 378XL about a month ago and have only used it once ( saving up cash and time off for a long run in the summer ). We had noticed that the light in the toilet seemed real dim and a pain to turn on and off if you are vertically challegend.
Travel on,
Bryan & Sue
byransues is offline   Reply With Quote
Old 12-31-2009, 03:18 PM   #19
kvtaylor's Avatar
By now you have your new Gerogetown all checked out. A lot was mentioned and is good advise. We also have a 2008 Georgetown 378 and also went thru re-aligning the front wheels. It was found when my dealer added the safe-T stablizer on it when it was new. Forest River paid for it. Ours has 18000 miles on it and the tires are running true. Also, the cabinet below the TV does get hot with the Fireplace is on high. We added a plastic cutting board in the cabinet and then added a VHS/DVD player/recorder in there. The plastic cutting board deflects the heat and saves the electronics. I also added a few holes for ventilation behind the TV for the heat to disapate.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
