One of my tires looks to be a little low. My tire infiltrator shows 65 psi. The load range says 95psi cold is that where i should be?
Thanks for your help!
Sounds like, but turned out to be only 5psi lower than goodyear Said it should be (70 psi). I also checked the right side tire wick wad exactly the same as the left side. All is well! Thank you for the reply!
