Old 04-16-2019, 09:54 PM   #1
Tire pressure.
George 35 with two slides.
New tires going on, 240/70/22.5
What kind of tire pressure should I run. 110 max.pressure at cold.
Swag is offline   Reply With Quote
Old 04-17-2019, 12:53 PM   #2
Iggy's Avatar
I suspect this is a used Georgetown and its getting its new set of shoes.
It all depends on the GVW of your Georgetown which should be on the wall behind drivers seat.
It also depends on the manufacturer of the tires.
They should publish a chart online.
Just an example for my Georgetown 378TS which is larger than yours and GVW 22,000 and weighs 20,000 lbs fully loaded and I have Toyo tires 245/75/22.5.
My front axle weight is 6,400 dived over the two tires = 70 psi
My rear dually axle weight is 13,600 divided by 4 tires = 75-80 psi
So you will have to do some homework before you can answer your question.
ID:	201979   Click image for larger version
2012 Georgetown XL - 378TS 63K + miles
Old 04-17-2019, 02:41 PM   #3
The only way to get an accurate pressure rating is to weigh your coaches front and rear axles then go the tires manufactures website and check their recommended PSI for your tire size.
I put about 2 - 4 PSI more than want they recommend.
When you are weighing your axles, have them weigh each tire individually as well, so you can balance out your coach when loading for a trip.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is online now   Reply With Quote
Old 04-17-2019, 04:39 PM   #4
Iggy's Avatar
My actual Georgetown weight
pressure, tire
