Old 12-14-2014, 07:42 PM   #1
MarkAnne's Avatar
Tire pressure
I can't find the tire pressure sticker/plate on my 2010 337DS. Where do they hide it?
2010 Georgetown 337 DS
MarkAnne is offline   Reply With Quote
Old 12-14-2014, 07:49 PM   #2
Love My Sunseeker
DXSMac's Avatar
Check your driver door or passenger door, whichever it is. On Class C's, they post it on the driver's door.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 12-14-2014, 09:23 PM   #3
Krazymace's Avatar
Mines on the wall behind the drivers seat.
Krazymace is offline   Reply With Quote
Old 12-15-2014, 01:42 PM   #4
If you cant find it or You have other then original tires placed , I can calculate it for you .
jadatis is offline   Reply With Quote
Old 02-08-2015, 08:19 AM   #5
MarkAnne's Avatar
I'm still stumped. Per my dealers suggestion I set the tire pressure to 95 pounds which is listed on the sidewall of the tires. The rig now rides like a truck and rattles and shakes like crazy. Any other thoughts on how to get the recommended tire pressure?
Old 02-08-2015, 08:34 AM   #6
Ford Idaho's Avatar
If the unit has air suspension what is the PSI set at?
Old 02-08-2015, 09:43 AM   #7
MarkAnne's Avatar
It does not have air suspension. change in ride it is strictly door due to higher tire pressures.
Old 02-08-2015, 10:31 AM   #8
Offer still stand as I wrote in my first reaction here.
So if you give the right data, I will calculate a pressure range in wich the tires are save and comfort and gripp are still acceptable.
Need from tires : maximum load or loadindex
Pressure needed for the maximum load /AT-pressure /maxloadpressure ( wich is not the maximum pressure of tire).
Speedcode of tire or maximum allowed speed.
And if they are ST tires , can all be found on sidewall.
From motorhome: GAWR's, GVWR ( gross axle/ vehicle weight rating).
But better would be seperate weighed wheel(pair) loads, second best axle loads.
Maximum speed you wont go over for even a minute in your use.
Configuration of motorhome, so number of tires front and behind.
Especially front mostly dont need high pressure , rear the 95 psi AT-pressure is mostly needed. And because driver and co-driver is mostly closer to front axle , bumping of front axle is felt .
Old 02-08-2015, 01:40 PM   #9
Freds342's Avatar
Look in the cabinet above the sink.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 02-08-2015, 01:56 PM   #10
abjb's Avatar
Did you find the "TIRE AND LOADING INFORMATION" sticker?
Our tag is located on the driver side above the seat belt.
2011 chassis with 235/80R22.5 says 90PSI.
It was delivered with 80PSI. I changed to 85 then 90 then 95 (max pressure on the sidewall is 110) finally set at 92.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
pressure, tire
