Old 11-08-2013, 11:29 AM   #41
Originally Posted by bubbles View Post
I have the 22.5" aluminum wheels and yes there is only the inner extender but the outer valve is readily accessible and is steel. Did you tell them that your wheels were not the 22.5" aluminum ones? Might make a difference. That's just not right to me. When my other MH's came with extenders it included the inner and outer when the wheels were the 19.5" variety with wheel liners. Sorry. You should be able to buy just the outer extenders if FR won't own up.
Mine are 19.5, I'm going to get a set of these:
Wheel Masters 8029180 180 Degree Valve Extender Package of 2 | eBay
The valve on the outer wheel is pointed inward and you can touch it through one of the cap's holes.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 11-08-2013, 11:30 AM   #42
Originally Posted by Iggy View Post
I think you said something wrong.
You are missing your inner extenders. The one you see in your picture is from the outside tire which you can work with.
I think you may have to send them a picture to explain what you are missing. The Inner tire extenders. Correct me if I'm wrong here.
Good luck
Iggy, I do have the inners, just need the outers. I did send FR a photo of the outer valve that I took in between the tires that shows there is no extender.
Old 11-08-2013, 11:32 AM   #43
Originally Posted by jk510 View Post
Those look to be the same hub caps as my Mirada. The come off pretty easily. If you look closely at the "lug nuts" you will notice that 2 of them are different. The difference is very slight, it is at the base of the "nut". Find one and the other is directly opposite.
I just went out and checked and found that the easiest way to find them is just by tapping on the "nuts". Most of them will sound hollow while two will sound solid. That those two off and the cap will pull right off.
Joel
Thanks Joel, I would have removed all of them. Good to know.
Old 11-08-2013, 11:33 AM   #44
Originally Posted by Phil57 View Post
When you get the valve stems figured out I would suggest getting the MH weighed then going to the tire manufacture web site to see what air pressure you should run. That's the only way to get it correct. Adjusting fir comfort is not safe or good for the long life of the tire.
How do I get the MH weighed?
Old 11-08-2013, 11:44 AM   #45
Ford Idaho's Avatar
Most truck stops have a public scale, you will need to pay a fee but it is well worth it.
Old 11-08-2013, 11:54 AM   #46
It's only around 9 dollars and good for the day. If you can find a scale that can do a four point weight that is best but hard to find. If you find one you can set your tire pressure more accurately. Most of the scales here in MI are Cat scales and only weigh the axel. That is better than nothing and will give you a starting point for tire pressure. The down side is having one side much heavier than the other and not having the tire pressure high enough.
Old 11-08-2013, 01:05 PM   #47
Phat Phrog Stunt Crew
awwall's Avatar
I decided to check the tire pressure on my rig and they were all set at 82. Sticker says it's supposed to be 97. For those of you with experience, do you find a better ride with the recommended pressure of a bit lower one.
I could only find four valves for six tires. Are the two on each side in the rear hooked up with a T? Another thing I noticed is that all of the valves are nice metal ones.
Just a question? Are you sure about the 97psi? My inside sticker says 82psi. I have 19.5 GY 670 tires. I weighed the coach and indeed, from the GY website, says my tires should be at 82psi for the weight that was measured on the scales.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 11-09-2013, 01:13 PM   #48
I must have read it wrong, it's actually 92 psi. Here is a picture.
Another question: Am I supposed t have a spare tire...if so, can't find it.
Old 11-09-2013, 03:41 PM   #49
Got the inner extenders secured and ordered a set of 180 hard line ones for the outer. Thanks for letting me know how the hub caps work. Mine had three fake lug nuts and they came off. I really like the design. They look real and if you ever damage one, just pop another one in. I also found that all of my wheels are balanced as they all good size weights in them. Probably why it rides so smooth.
Old 11-09-2013, 06:44 PM   #50
Networx's Avatar
Al - no spare tire, we couldn't change it anyway, so no need. Have a good roadside service and they will bring one.
Brian & Amy Gregory
Becca (19), Bethie (16), Nate (12)
2013 Georgetown 351ds sold http://www.forestriverforums.com/for...ies/crying.gif
2013 Jeep Wrangler Sahara Unlimited Toad with ReadyBrute Elite
Networx is offline   Reply With Quote
pressure, tire
