Old 09-13-2013, 09:09 PM   #21
Iggy's Avatar
Originally Posted by Newellri View Post
Thanks ever so much, you are a great asset to this thread!
Thanks. Now id only we can find out why the diode blew.
I'm unable to find what the diodes serve. They allow DC voltage/amperage to flow one way and not the other.
What I have read they may become hot for some reason and that causes them to blow open. They have something to do with power to the Power Control Module and get power thru one or all of the relays at the bottomof the fuse panel.
Oh well we now know where to look if you lose toad turn signals and brake lights.
Old 09-13-2013, 09:24 PM   #22
Newellri's Avatar
I pull a 2010 jeep liberty----- we have a battery disconnect was told it needed it but they did not know why. Well I quit using on short trips, I suspect it may have got a feed back from turn signals with the battery not disconnected.
Newellri is offline   Reply With Quote
Old 09-13-2013, 09:26 PM   #23
Newellri's Avatar
As a side note it was 101 Monday in Des Moines IA ----- I don't think it will be more than 70 Sat. If you don't like the weather in IA just wait a couple of days.
Old 09-15-2013, 10:22 AM   #24
Folks I was wondering if any of u had a fuse diagram for a 08 Georgetown XL model 359. I saw Iggys post and was hoping it was the same. However, I checked the fuse and it was fine. Sorry I'm having the same issue with the left turn signal on my toad.
Pkowski is offline   Reply With Quote
Old 09-15-2013, 10:48 AM   #25
Iggy's Avatar
Did you check the diodes I circled in this picture?
Hopefully you know how to check a diode.
Use multimeter Ohms setting.
You should get continuity one way and switching test leads NO continuity the other.
Old 09-15-2013, 11:35 AM   #26
Pete
gartonhl's Avatar
Unhappy
Originally Posted by Iggy View Post
What are you not getting at the plug in the rear of the motorhome?
Brake light power?
Turn signal power?
Have you checked your Ground?
One fuse will not stop all power to the rear plug....
2010 GT 378, toad=2012 Jeep Rubicon
Had same problem described above, with one addition. The Invisibrake in Jeep wouldn't activate, nor would the Invisbrake dash light in the motorhome light up when MH brake was depressed.
Thought it was a fuse issue-was NOT. To Camping World for help. The ground wire in the plug to motorhome was corroded and dirty at the point where the ground wire attached to the connector pin in the plug. I could not see corrosion, etc. by just looking into the plug. They replaced plug; everything works fine now. If there is a next time, I'll break down the plug and clean before taking it in. Love those "life experiences".
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 09-15-2013, 01:10 PM   #27
Nope. Will do and let u know. Thanks.
Old 09-17-2013, 07:43 AM   #28
Iggy
Checked diode it was good then I checked the plug connection in my toad. It was corroded so I cleaned it and of course, it worked. I should have done that first cause the connect has been installed since 04.
Live and learn.
Thanks for your help
