Old 07-25-2011, 06:36 AM   #11
I tow my Altima on a dolly with electric brakes. You do not need a braking system for the car, only the dolly. Check your weights for towing and your Gross Combined Vehicle Weight--the car, cycle, dolly and rig loaded. I use the lights on the dolly only and have not had any problems being noticed.
2010 373DS
Master Tow with 2008 Nissan Altima
bresdogsr is offline   Reply With Quote
Old 07-26-2011, 11:21 AM   #12
raoulwv's Avatar
I assume your 373 is on a Ford chassis with a 22,000 lb. GVWR and a 26,000 lb. GCWR. If so, according to Ford, you have a 4,000 lb. tow rating even if you have a 5,000 lb. hitch. I doubt the combined weight of a car, motorcycle and tow dolly will be lower than either of those numbers. You also need to consider the vertical hitch weight of your set up.
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '14 Ford Focus toad
raoulwv is offline   Reply With Quote
