Old 02-02-2014, 10:12 AM   #1
Toilet issue on Sealand SC-210
Last night when I went to flush, I heard a sound that led me to believe something had broke. I then let go over my foot on the pedestal and the ball valve would not go shut. In the meantime, I'm manually, shutting the valve by using my hand on the pedestal.
I'm thinking the spring mechanism has broke somehow and I will need to replace it. It seems fairly easily. While I'm at it though, I think the ball valve should also be replaced just for general maintenance.
I could hire a mechanic to do this but was wondering if anyone has done this themselves? Is it pretty easy or difficult? I read something on EHow on how to do this and it seems easy enough but could be tricky dealing with the ball valve. It says to be careful or the thing could end up in the holding tank. Some of the steps seem to be missing from the Ehow procedure so not sure how much I trust it. So I'm on here to see if any of you have done this and have advice. Thanks for your response in advance.
georgetown50 is offline   Reply With Quote
Old 02-02-2014, 01:29 PM   #2
I had the same issue with mine. I called Dometic with my serial number and model and they sent me a new free toilet to my house. It was an easy install.
Old 02-03-2014, 12:52 AM   #3
I guess your toilet was under warranty. How long had you had it? My RV is a 2007. I'll call and see but I'm not sure they would do the same for me.
Old 02-03-2014, 11:28 AM   #4
If I'm not mistaken mine was over a year old but they said it was a defect in the toilet when I gave them my serial number. Can't hurt in trying. If you go have to buy a new one get the 320 which is the newer model.
LINK
Video Link
Good luck
Old 02-06-2014, 12:43 PM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
Dometic - SeaLand 210 Toilet Manual.pdf
Dometic Traveler Lite 210 RV Toilet Owner's Manual.pdf
Dometic - Parts Lists 110 & 210 Toilets.pdf
If you decide to go the repair route here are the Manual & Parts List for the Toilet. I have a 2007 Georgetown as well. So far I've only needed to replace the seals from the bowl to the stand twice. Most of these parts are available on eBay for a lower cost than the dealerships.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
