Old 03-24-2014, 10:37 AM   #11
I'm in it right now watching TV through the antenna. Booster on with 4 out of 5 bars. Turn microwave on and no problems. I turned the booster off and get 2 out of 5 bars...micro on and no problems. I've never had issues with micro interference. IMO, the booster has nothing to do with it. However, if the coax from the antenna is running really close to the microwave, I can see it interfering.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 03-24-2014, 10:47 AM   #12
TURBS's Avatar
Good possibility!
TURBS
Sabre owners united!
Old 03-24-2014, 11:00 AM   #13
What model coach do you have? Is it the 329 with the TV over the kitchen counter, by any chance?
Scagsdale is offline   Reply With Quote
Old 03-24-2014, 11:48 AM   #14
Krazymace's Avatar
My coach is 335. TV and microwave separated by fridge and pantry.
Krazymace is offline   Reply With Quote
Old 03-24-2014, 11:51 AM   #15
Krazymace's Avatar
My coach is a 335. Microwave and TV separated by fridge and pantry.
Old 03-24-2014, 12:22 PM   #16
B and B's Avatar
I highly doubt the microwave is leaking 2.4 ghz the frequency of most units. The TV is most likely getting interference on the AC poser line. Both the TV and the Microwave have switching power supplies. The operation of these supplies spread interference through improper filtering on the AC side. The booster certainly can enter into the picture though powered by 12 v gets that from the converter. I have no real solution to the problem other than replacing the microwave, try another one a see if the problem goes away. As far as Toshiba, I have not seen a Dumount, Zenith or Admiral TV lately so that is what we have.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-24-2014, 02:17 PM   #17
Witch Doctor's Avatar
AS I said in an earlier post, check to find a filter to take the noise out of the ac line, your problem will be over.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-24-2014, 02:43 PM   #18
Krazymace's Avatar
I also have two Toshiba TVs. I'm sitting here watching HD channels and just ran the Micro and have zero issues. Your Micro should never interfere with a TV signal. Check for leaks: 4 Ways to Check a Microwave for Leaks - wikiHow
If you have HD, you must be on something other antennae if you are watching HD. My problem is antennae mode in both SD and Digital.
Old 03-24-2014, 02:43 PM   #19
Krazymace's Avatar
Meant analog or digital
Old 03-25-2014, 10:52 AM   #20
Krazymace's Avatar
Seems like I need and electrical noise filter. Would I install that for the microwave or the TV's?
