Old 05-25-2014, 07:37 AM   #1
Toshiba TVs Burning Up
Please post if you are having issues with your living area Toshiba TV.
Everything was fine and all of the sudden lost the picture. Could not get it to do anything with the remote, only sound was coming out. Had to unplug/plug it to get it to come back on.
It seemed everything was fine until I ran auto scan for air channels and none were found. I knew there was a problem since we have camped in the area several years with 10+ air channels.
Before checking into the amp and antenna I decided to unplug the coax from the TV since it had earlier issues. Sure enough all channels came back.
Now I need to figure out how to get it replaced. I believe the issue is with the fact that the TV doesn't have adequate ventilation and it's burning up.
Not sure if I have to take it up with Toshiba or Forest River. I haven't checked the paperwork for warranty details. Someone mentioned that it was 90 days, in which case, I'm out of luck.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-25-2014, 08:47 AM   #2
I'd take back to the Forest River Dealer. Your dealer will get a new TV from Forest River for you, if required. Forest River needs to handle this so they have the opportunity to document a possible problem with this Toshiba model. If there are others having the same problem then FR would have the documentation to break it off in Toshiba's butt. If it is a ventilation problem then it would absolutely be Forest River's problem. One they need to fix.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-25-2014, 10:46 AM   #3
Cornelius's Avatar
The original owner of my Georgetown had the Toshiba TV replaced, although I do not know the specifics. I found paperwork that the TV had been replaced, and the owner's manual that came with the Georgetown was for a different model Toshiba.
So far, it continues to work well, but if it ever fails I would replace it with a much more efficient LED/LCD television.
Cornelius is offline   Reply With Quote
Old 05-25-2014, 01:54 PM   #4
That's the problem. We refuse to go back to the dealer we purchased it from and it's not close by The dealer that's closer to us has no interest in helping out because we didn't buy it from them.
Now, the statement below is directly from the Toshiba's manual.
[Always leave a space of at least 4 (four) inches around the TV. The slots and openings are provided to protect the TV from overheating and to help maintain reliable operation of the TV.]
The TV sits recessed into the wall and with less than 1" on each side, and less than 2" on top and bottom. Everything works fine with the TV, but the minute you install the coax cable it jacks up the signal for all other TVs. It must be internally shorted or something in the input board.
I'm hoping to hear from other members before presenting the case with FR. I may get more replies in irv2 though.
Old 05-25-2014, 02:00 PM   #5
rattleNsmoke's Avatar
Mine 'burned up' the end of last summer. I replaced it with a 32" Samsung LED. The only downside is that the Toshiba was a 37" and the Samsung is smaller. I had plenty of ventilation around the unit. The tv would turn on, then go off. I figured it was toast.
rattleNsmoke is offline   Reply With Quote
Old 05-25-2014, 04:06 PM   #6
camaraderie's Avatar
Suggest you contact Toshiba directly as they have a standard 1 year warranty which you can access here.
http://cdgenp01.csd.toshiba.com/cont...168010_web.pdf
Excerpt of Exclusions:
What Does this Limited Warranty Not Cover?
Service made necessary by accident, misuse, abuse, neglect, improper installation/maintenance, modifications, fire, theft, acts of God, power failures,
surges or electric shortages, lightning, or repairs by non-Toshiba authorized service providers, use outside of the environmental or operating parameters, or use with incompatible third party products
Two things can happen:
1. Toshiba will fix or replace the set OR tell you how to solve the problem at your end.
2. Toshiba will tell you that the product is installed incorrectly and that their warranty is invalid.
If #2...you now have written evidence to pass to Forest River that THEY are responsible for the problem....and they should fix it.
Either way... you get the problem fixed.
camaraderie is offline   Reply With Quote
Old 05-25-2014, 04:11 PM   #7
Originally Posted by camaraderie View Post
Suggest you contact Toshiba directly as they have a standard 1 year warranty.
Exclusions:
Thanks, makes sense. I'm also going to have to replace the mounting bracket. There is plenty of room for it to stick out a lot more. If this heating issue is just a TV glitch then no problem. However, if I'm not the only one, then FR needs to come up with a solution as the same thing could happen to the next TV.
Old 05-26-2014, 04:28 PM   #8
Cornelius's Avatar
Instead of replacing the TV mounting bracket, you may be able to re-use the original bracket and just bolt a 1 or 2 inch thick piece of wood behind the wall side of the bracket to extend it out a little further to increase the ventilation.
Old 05-26-2014, 04:41 PM   #9
That is a great tip. I think that with a tilt mount would do the trick. That way I can sit in the Euro chair with a better viewing angle. Thanks.
Old 05-26-2014, 04:51 PM   #10
Oaklevel's Avatar
Ours is going on two years old & no issues yet ..... Our dealer suggested not to leave it outside in the winter months, so we bring it in & use it in our guest bedroom. Have no idea if he knew what he was talking about but it made sense & couldn't hurt. TVs are made to get warm but not made for sub freezing temps real bad to turn them on while below freezing til after they warm up to room temp. ????? Its just what the dealer told us...
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
