Old 12-13-2010, 09:16 AM   #11
My last coach had a workhorse chassis and let me tell you this ford tow haul aint no workhorse w22 with tranny brake.With the workhorse I was able to desend steep grades out west without ever touching the brake.With the ford tow haul the coach tends to run away even on moderate grades.Workhorse is no longer building RV chassis because of their big recall on defective calipers but I am sure going to miss them.
johnnypal is offline   Reply With Quote
Old 12-13-2010, 10:11 AM   #12
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
The 2011 Ford V10 Chassis has a transmission brake also. If I did this right you can read about it in the attachment.
Motorhome_ClassA_Catalog.pdf
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 12-13-2010, 10:27 PM   #13
Well I am now in Palm springs area and the motorhome performed admirably. The breaking on hills was pretty darn good. I can't say it was as good as an exhaust brake but it was good.
I was even more surprised by the hill climbing ability. Although not recommended for good gas mileage I put it in cruise at 55 mph and I went over the Siskiyou summit and only dropped down 5 mph. The engine was torquing it pretty good and the tach showed it was reved up to 4000 RPM but it went over the summit passing even the diesels except for those without any trialer in tow. I was impressed.
Lloyd
starburst2 is offline   Reply With Quote
Old 12-13-2010, 11:21 PM   #14
BOBFIDY's Avatar
.....4000 RPM.......I'll bet that thing sounded like a chain saw.
Not sure I want to buzz mine that high RPM for very long.
Just saying.......
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 12-16-2010, 04:16 PM   #15
nemo45's Avatar
4000 rpm doesn't sound too bad. But, if you have the cruise set at about 62 mph and you go up a grade like that it, pops up to about 4800 rpm and that is pretty nerve racking.
georgetown
