Old 02-04-2016, 04:11 PM   #31
Originally Posted by Jim G View Post
My Tow/Haul has also quit working in a 2012 337XL. The indicator light on the dash also does not light on start up. It acts like a fuse, but I have checked every fuse in the fuse block under the dash as well as the mower distribution box under the hood as well as fuse number 18. I am told by ford that it is added aftermarket and they do not know the fuse location. Also when contacting FR I was sent manuals but the fuse location is not shown. I have been under the dash and cannot find it. Any ideas ?
It is definitely a ford issue and I bet the wires in the steering column is broken mine was covered under warranty
2014 Georgetown XL 378
kgreen is offline   Reply With Quote
Old 02-04-2016, 04:16 PM   #32
Kenny kustom's Avatar
Also, just as an FYI...
The " shifter" is very fragile.
There is an inner sleeve and an outer sleeve. Both made from some sort of cast metal. Try not to park on a slope, that would put pressure on the shifter, when placed into " park". I've replaced quite a few.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 02-06-2016, 08:37 AM   #33
Thanks for the input. There is a recall on this chassis for a shifter linkage issue, I have made an appointment to get it looked at while the recall is being done.
Jim G is offline   Reply With Quote
