Old 03-24-2011, 07:31 PM   #1
Towed question
I'm new to the towing behind a Class A thing and I have a quick question. Does towing behind the RV rack up miles on the Towed vehicle's odometer while it is being towed? I will be towing a Ford Edge if that helps. Thanks, looking forward to traveling in a Class A this season!
Col-man is offline   Reply With Quote
Old 03-24-2011, 07:52 PM   #2
bikendan's Avatar
just a note, it's referred to as a "Toad" or dinghy towing, like on boats.
Old 03-24-2011, 08:08 PM   #3
Told you I was new to this. Thanks for the info on it being called a toad!
Old 03-24-2011, 08:30 PM   #4
Send a message via Skype™ to scubieman
Col- man. Your odometer is connected to your tranny. You tow with tranny in neutral on your TOAD. Therefore tranny does not turn. So therefore you WILL NOT put miles on your vehicle.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 03-24-2011, 08:31 PM   #5
sherdep's Avatar
if the toad has electric speedo then no it will not add mileage to the speedo
but keep in mind it still puts wear and tear on the tires and if it isnt a 4 wheel drive or standard shift to put the trans in neutral yjen you will need a driveshaft disconnect
also you should have something to engage the brakes in the toad for added safety as well as applying the brake lights to the toad
I know some of this because my parents have 40 footer diesel pusher and have helped my father out of an electrical jamb he paid someone $500 to do it and they made a mess of it and had to straighten the wiring out
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-24-2011, 08:33 PM   #6
Good point sherdep. If it's 4x4 you need to put transfer case into Netural. Most owners manuals have (how to tow with wheels down). Even my 2500 dodge ram has it.
Old 03-24-2011, 08:40 PM   #7
sherdep's Avatar
Thanks - it helps to have someone (My Father) that has gone thru this and I asked a bunch of questions cause knowledge is power and besides the fact that if I ever decide to upgrade to a Motorhome I will already be one step ahead.
If not I would have to find a good forum like the one we are memebers of and ask questions just like the OP has - and it looks like he got some good help here to
Old 03-24-2011, 10:12 PM   #8
RANGERBOB's Avatar
I Don't know but my TOAD gets great gas mileage!!
RANGERBOB is offline   Reply With Quote
Old 03-25-2011, 07:30 AM   #9
Rugged Brown's Avatar
I must have been doing something wrong all these years. I pushed my MH with a VW Jetta. Terrible gas mileage and several engines later.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 03-25-2011, 10:45 AM   #10
Col-Man
We are pulling a ford edge with our Georgetown and it is just great. We have a even break to help on breaking and the only problem was the even break pulled our car batteries down. The solution was to stop (which we had to do anyway) every 200 or 250 miles and run the car engine. This was was on a 6500 mile trip to the west coast and up across to the Glacier national park and down. It was a great trip and we bought a portable battery charger to case we forgot to stop. The restrictions for the edge was 65miles per hour which we didn't have aproblem with because we like to smell the Roses.
We love the Ford Edge.
Ron and Carolyn
GeorgieGirl is offline   Reply With Quote
Old 03-25-2011, 03:07 PM   #11
sherdep's Avatar
Originally Posted by GeorgieGirl View Post
Col-Man
Ron and Carolyn
My father had the same issue with it killing the battery - was due to the moron that wired up the toad didnt hook the +12 volts to the battery which charges the battery as you go down the road as long as you are hooked up to the Motorhome.
I had to re-wire my father's motorhome to fix that same issue - if I had hooked up what was supposed to be the +12 volts - it had actually +24 volts - would have had a nightmare.
My father paid someone $500 to re-wire his toad to his motorhome and when I looked at it I was like I would be ashamed to let this out of my shop looking like this - wires were everywhere and a mess.
Good thing for Multi Meter's
Old 06-18-2011, 06:44 PM   #12
We pull a 2010 GMC terraine & NO it does not rack miles when being toed
CanadianRVER is offline   Reply With Quote
