Old 10-04-2013, 03:33 PM   #1
Towing a Motorcycle
Here is a question for those of you that tow a motorcycle on the hitch. I've seen quite a few out on the road, but the folk at the motorcycle forum I belong to say not to do it.
We were going to buy a Jeep Cherokee to tow behind because my truck is too heavy and the wife's car is AWD. We then realized it will be a PITA so we decided to rent a vehicle wherever we end up. However, for shorter trips within the State we would like to have something to put around in case we need something from the store. I have a couple of bikes that would do the trick, but not sure how safe it is to tow. I was looking at a carrier that you put the bike in sideways behind the coat and it mounts to the hitch. It is rated up to 1k lbs, and my bike only weights around 500 lbs.
Like I said, the folks at the motorcycle forum say it would be too much weight on the tongue and too much stress on everything.
Any suggestions from experience?
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 10-07-2013, 01:33 PM   #2
Retired US Army CW4
Tom and Kat's Avatar
I normally pull my Jeep behind the motorhome but I have a hitch mounted carrier that I used to carry a Honda CRF450. It seemed pretty "maxed out" with the Honda on there and it only weighs about 225. I don't think I would want anything heavier than that on there. It moved around and bounced up and down a lot and I did nothing but worry the whole time it was back there. I even welded a bar to the carrier that would bolt to the side of the receiver for stabilization. I ended up buying a small trailer for the bike(s) and I'm a lot happier.
2014 Georgetown 329DS
Towing a 2011 Jeep Wrangler JKU w/ReadyBrake
Yorkie guard dog on the dash
Tom and Kat is offline   Reply With Quote
Old 10-07-2013, 02:26 PM   #3
Missing Link
cyclepuck's Avatar
A buddy hauls his Harley on one with out issue. As long as you're hitch and coach is rated to haul the weight it won't be a problem. If all else fails get a nice little motorcycle trailer.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 10-07-2013, 05:12 PM   #4
The one I was looking at is beefier than that one and it's rated for 1k lbs.
Old 10-07-2013, 05:16 PM   #5
I've seen coaches hauling bikes and the reason I ask. The bike I want to haul weight max 500 lbs and the carrier I was looking at is rated for 1k lbs. Not sure what the tongue weight is for my coach, I just know that the hitch is rated for 5k lbs.
I have an 8x12 utility trailer with motorcycle chocks installed, but I hat to have to make the coach even longer. Maybe a small one bike trailer would work, but wondering how you'd go in reverse if you had to.
Old 10-07-2013, 05:55 PM   #6
Retired US Army CW4
Originally Posted by alparmmer View Post
I've seen coaches hauling bikes and the reason I ask. The bike I want to haul weight max 500 lbs and the carrier I was looking at is rated for 1k lbs. Not sure what the tongue weight is for my coach, I just know that the hitch is rated for 5k lbs. I have an 8x12 utility trailer with motorcycle chocks installed, but I hat to have to make the coach even longer. Maybe a small one bike trailer would work, but wondering how you'd go in reverse if you had to.
The mounts that are rated to carry the heavier bikes normally require additional supports that are welded to the frame rails on the motorhome. You have to make sure that the motorhome and the frame are rated for the extra weight. That is why you usually see these carriers on diesel pushers. The frame extensions on the gas rigs are normally not rated for the extra weight.
Old 10-07-2013, 06:07 PM   #7
Thanks for explaining, makes sense. Small bike trailer it is.
Old 10-07-2013, 09:21 PM   #8
Missing Link
cyclepuck's Avatar
http://www.discountramps.com/motorcycle-trailers.htm The kendons are real nice if you don't mind the price.
2014 Puma 30-DBSS
Old 10-07-2013, 09:30 PM   #9
Retired US Army CW4
They make the Kendon trailers a couple of miles from my house in Anaheim. First class operation that builds quality trailers. They also fold up and roll into your garage standing up.
Old 10-08-2013, 06:37 AM   #10
Oh, those are nice trailers. I like the swivel one since you can back up without a problem. Showed the wife and when she saw the $$$, she gave me the evil eye. She said it would be cheaper to rent a car wherever we go. Really?
towing
