Old 06-09-2016, 09:38 AM   #11
bubbles's Avatar
Originally Posted by Dijoeboss View Post
I have not myself checked voltage, but was checked when under warranty and I was told it was good, front a/c is a 15k, rear is a 13.5K, Onan 5500, just changed oil and filter last weekend, Onan filter/ 15w40 oil. New air filter, new fuel filter, new plugs, 735 hours on generator. But, it's done this since new......
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Do you know if the generator was checked with a load bank connected (was it checked by onan or dealer). Was the frequency output also checked?
Old 06-09-2016, 09:58 AM   #12
Head Rambler
This sounds like the relay dropping out due to low voltage. Some relays are fairly sensitive to voltage.
Gotta go campin!
Old 06-09-2016, 11:58 AM   #13
Chuck.C's Avatar
This may be a long shot, but...
Typically, each A/C unit runs off a different 50 Amp leg. If someone miswired it, they may share the one leg, which will usually work when you have shore power, but with only 30 amps from gen, will probably fail.
If you can get them both running, switch off one breaker at the gen. One should quit. If both do or neither does, you've found the problem.
2013 Coachmen Mirada 35DL
Chuck, Susan, and dogs- Gracie the Registered SnackHound and Toby the Wonder Boxer
Chuck.C is offline   Reply With Quote
Old 06-09-2016, 08:46 PM   #14
Dijoeboss's Avatar
Name:	ImageUploadedByForest River Forums1465523176.965716.jpg
My temporary fix......
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 06-09-2016, 08:58 PM   #15
Dijoeboss, you need to watch out doing what you have done. If you forget and plug in shore power you may damage the inverter in the generator.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-09-2016, 09:16 PM   #16
Dijoeboss's Avatar
I won't forget.... This is an issue I've been dealing with for 3 years.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Old 06-09-2016, 10:12 PM   #17
Bummer
Mine has shut down a few times, but only when I an on generator power, driving and hit a bump in the road
2008 Honda CR-V
Old 06-10-2016, 04:39 AM   #18
cjd10's Avatar
Bummer
I have found that keeping the oil level completely full helps that. If mine is low on oil just a little bit I have that issue.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 06-10-2016, 06:30 AM   #19
I keep mine checked
2008 Honda CR-V
Old 06-10-2016, 08:01 AM   #20
Head Rambler
I was thinking the same thing.
I think I'd put a big ole tag on the blades of the shore power plug to remind me to remove the jumpers before plugging it in, just in case you get in a hurry, or in case someone besides you happens by and wants to do you a favor. Or in the event something happens and someone else has to make or break camp for you.
Gotta go campin!
transfer switch
