06-08-2016, 06:05 PM
Transfer switch won't stay engaged
I've listed this problem in another thread, but today right now, I can't run both a/c units without the transfer switch tripping out when the back a/c unit compressor tries to engage, I have to turn both a/c units off, wait for the transfer switch to engage, start the front unit, wait til compressor pulls in, start back one, fan comes on, then when the compressor tries to engage, transfer switch kicks out, there's NO other loads on, fridge is off, water heater is off, no lights on..... This system has got me frustrated and tired of messing and stressing with it!!! Any ideas???! Thoughts????
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-08-2016, 06:18 PM
Yesterday at this time, both a/c units worked ok after the 2nd attempt, now both units are working after about 6 attempts. I'm missing something, not sure what.....
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-08-2016, 06:32 PM
Interesting and thanks for more input.
As far as I know the transfer switch that comes with the Georgetown between the generator and shore power is just a switch and has no circuitry that monitors amperage and only sees shore power or generator power and switches to that source.
Is this only happening at one campground or multi?
Now if you are having specific issues when on generator power and both AC running it may be that you are exceeding the amperage of the generator and its tripping off.
You just may have one AC starting to fail the way you talk about the compressor kicking in and the power disconnects.
No tripped breakers?
Has the generator mounted circuit breakers ever trip?
Are you in a very hot area?
Are you at a high altitude?
These all relate to the generator and not the transfer switch.
If it happens on both generator and shore power I would look for some loose wire connections in you cable or at the transfer switch.
Have you actually measure with a meter what voltage you are getting from generator and or shore power?
This would tell more if you could do that.
06-08-2016, 06:43 PM
What happens if you turn on the back then the front? I am wondering if that rear one is pulling more amps for some reason. Do you have hard start capacitors?
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
06-08-2016, 09:36 PM
This issue has been an issue since I bought it in Feb.2013, has16K miles on it now, I replaced the transfer switch with a new Furrion unit just like what I took out, same issue, IT ONLY HAPPENS ON GENERATOR POWER, never have any issues on shore power. I'm in Oklahoma 1000 ft. Sea level, today's high temp was around 90' I've had 2 different dealers check it out under warranty, can't duplicate concern / no problem found etc. both a/c units have been checked for amp draw and was ok / in spec range at the time of testing. I go through this every summer and I'm just so over it already.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-08-2016, 09:39 PM
I added hard start capacitors 2 summers ago and can't tell that they did anything to help.
I have not actually checked the voltage from the generator myself. Was checked under warranty....
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-08-2016, 10:41 PM
Have you checked the generator output voltage with a meter when running both AC?
Are both AC the same size?
I have a 15,000 btu front and a 13,500 btu bedroom.
Is your generator an Onan 5500?
How many hours on the generator?
When was the last oil change?
06-09-2016, 06:03 AM
Mine does the same thing under generator power only. Had for a year, will run one a/c but not both. Even then it may trip (jump). Dealer says they can't duplicate but I am not crazy. I think that the issue is a heat issue. As you run more amperage things get hot, running both a/c means it also hot ambient temperature. Running down the road the compartment get hot. Heat and electrical things don't work well together. I know it is called a switch but to me it is really relays that have coil. When they get overheated they chatter then you loose power.
Just an idea, but still does not fix this.
06-09-2016, 07:59 AM
You are absolutely correct.
On my 5500 watt Onan I have 2- 30 amp circuit breakers and yes during hot weather the generator may stop if the oil is low and will make it shut down on heavy loads.
Many people have seen this.
Good luck all.
06-09-2016, 09:03 AM
I have not myself checked voltage, but was checked when under warranty and I was told it was good, front a/c is a 15k, rear is a 13.5K, Onan 5500, just changed oil and filter last weekend, Onan filter/ 15w40 oil. New air filter, new fuel filter, new plugs, 735 hours on generator. But, it's done this since new......
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-09-2016, 09:38 AM
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Do you know if the generator was checked with a load bank connected (was it checked by onan or dealer). Was the frequency output also checked?
06-09-2016, 09:58 AM
This sounds like the relay dropping out due to low voltage. Some relays are fairly sensitive to voltage.
Gotta go campin!
06-09-2016, 11:58 AM
This may be a long shot, but...
Typically, each A/C unit runs off a different 50 Amp leg. If someone miswired it, they may share the one leg, which will usually work when you have shore power, but with only 30 amps from gen, will probably fail.
If you can get them both running, switch off one breaker at the gen. One should quit. If both do or neither does, you've found the problem.
2013 Coachmen Mirada 35DL
Chuck and Susan, RIP Toby and Gracie, the greatest dogs.
06-09-2016, 08:46 PM
My temporary fix......
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-09-2016, 08:58 PM
Dijoeboss, you need to watch out doing what you have done. If you forget and plug in shore power you may damage the inverter in the generator.
2013 Georgetown XL 378
2008 Honda CR-V
06-09-2016, 09:16 PM
I won't forget.... This is an issue I've been dealing with for 3 years.
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
06-09-2016, 10:12 PM
Bummer
Mine has shut down a few times, but only when I an on generator power, driving and hit a bump in the road
2008 Honda CR-V
06-10-2016, 04:39 AM
Bummer
I have found that keeping the oil level completely full helps that. If mine is low on oil just a little bit I have that issue.
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
06-10-2016, 06:30 AM
I keep mine checked
2008 Honda CR-V
06-10-2016, 08:01 AM
I was thinking the same thing.
I think I'd put a big ole tag on the blades of the shore power plug to remind me to remove the jumpers before plugging it in, just in case you get in a hurry, or in case someone besides you happens by and wants to do you a favor. Or in the event something happens and someone else has to make or break camp for you.
Gotta go campin!
