Old 06-08-2012, 06:53 AM   #31
KyDan's Avatar
Originally Posted by grayfox View Post
Beer in the frig... don't think so. Ice it down in the cooler.. only way to go.
I have a couple of beer mugs that are plastic with "blue ice" type stuff
inside. I put them in the freezer and my beer in the fridge.
Even tho the fridge typically runs almost 40 deg F the freezer is nice and cold.
When I pour one of those 40 deg beers in the freezer mug it gets ice on top
and if I let it sit long enough it will turn slushy.
You can't get much colder than that!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 06-08-2012, 06:53 AM   #32
Namchief's Avatar
Originally Posted by f1100turbo View Post
This thread is ending up like the last one.
Namchief u from up around hayward?
Just a bit north and east but yes I am from around Hayward
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 06-08-2012, 07:00 AM   #33
Namchief's Avatar
Originally Posted by herk7769 View Post
Ran into the "propane cops" going through the tunnel in Baltimore on I95
AFTER I paid my toll, I was told by the toll taker to pull over to the shoulder and was met by a Trooper who issued me a 100 dollar ticket.
When I complained about the size of the fine, he said I could choose the other one. I said what was that one? He said "Risking a Catastrophe" and that fine was 1000 dollars.
The Chesapeake Bay Bridge and Tunnels also have propane restrictions.
They make you pull over and they check that you meet the requirements before you can proceed. Chesapeake Bay Bridge-Tunnel -- GAS REGULATIONS
Herk this is BS what are you going to do with a fricking 20 or even 30lb cylinder? I bet 55 gallon drums are still ok to travel with and that is what was used in almost every terrorist attack. This will not stop people untill e everyone that can see the BS calls into their elected puppet and lets them know how they feel.
1999 Yamaha Grizzly
Old 06-08-2012, 08:15 AM   #34
It was that way for the Baltimore harbor tunnel before 911 and always has been for the most part.
grayfox is offline   Reply With Quote
Old 06-08-2012, 08:32 AM   #35
KyDan's Avatar
Chill out!!
If an RV is involved in a bad wreck while in the tunnel, it is much more
likely to spark a fire IF the LP is on.
Puncturing a tank is possible but if the LP tank is ON all that has to happen
is for a hose or pipe or tube anywhere in the RV to get damaged and you
have spewing LP.
Can you imagine a raging smoking fire in a tunnel with 100s of cars all backed
up bumper to bumper and no way to get out??
This is the stuff of nightmares and scary movies!
I get the reasoning.
In Lou's case a warning would have been more neighborly.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 06-08-2012, 09:59 AM   #36
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Originally Posted by KyDan View Post
Chill out!!
have spewing LP.
Ditto!
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 06-08-2012, 10:08 AM   #37
I guess I'm one of the few that won't travel with my propane on, unless the trip is over about 5 hours drive. I always turn if off before re-fueling, why take the chance? If it's less than 5 hours drive the fridge stays plenty cold.
Len & Cheri is offline   Reply With Quote
Old 06-08-2012, 10:36 AM   #38
Originally Posted by nemo45 View Post
Ditto!
X-2
Old 06-08-2012, 10:41 AM   #39
Chill out!!
have spewing LP.
Big (Propane powered) delivery trucks for years have been used. Guess what the truck that delivers propane for our area runs on (Propane). I do not think these are traveling (Bombs) any more than a vehicle with (Gas)! Involved in a wreck,anything could happen! Youroo!!
Old 06-08-2012, 11:09 AM   #40
I had a bad wreck in my TT 2 years ago. The trailer rolled over and was completely destroyed. Both 30 lb. LP tanks were on at the time. The front end where they were was completely smashed and at first I could not find the tanks in the debris. When found, they were both intact, hoses ripped off, valves open BUT not leaking and still partly full. Why? Because for several years valves have been required to have an automatic shut off if a rapid flow is detected. LP tanks thus equipped are a hazard only if the tank itself is ruptured, which could happen with the tank on or off.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
led pad
