Old 05-05-2013, 06:19 PM   #1
Trying to change valve stems on Alcoa Rims
I'm trying to change out my outboard dually valve stems. Went to a local tire shop and agreed on a price. Went to take off the tires and the shop did not have a tool for taking off the chrome caps off the lug nuts. Have a question? Are there just 2 caps that come off and then the center cap comes off so you can get to the wheel lug nuts? I have never had the 22.5 Alcoa rims before.
Marty
2007 Georgetown XL 378
"EZE-TOW" Dolly
2010 Toyota Prius
mkaminski is offline   Reply With Quote
Old 05-05-2013, 06:33 PM   #2
Leathergypsy's Avatar
Are you talking about wheel simulators? If you are, yes should be 2. Opposite from each other. You should have a T handle tool somewhere. fits over the lugs.
John N.
Madison Heights, Mi.
2009 Salem LE 27RBEC
2013 F250 Lariat 6.2L
Leathergypsy is offline   Reply With Quote
Old 05-05-2013, 06:37 PM   #3
Is this what you have?
John N.
Old 05-05-2013, 06:41 PM   #4
I believe so, the center part that sticks out. I purchased my rig used and didn't come with the T handle. Will this work? Lug Nut Cover Pliers — always shiny wheels and rv
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-05-2013, 06:42 PM   #5
Yes, that is what I have.
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-05-2013, 06:44 PM   #6
Iggy's Avatar
Marty this is the tool you need. Is it possible that it is in a drap or some hidden place? That is if you bought the Motrohome new you shoul;d have gotton one.
Old 05-05-2013, 06:47 PM   #7
Yeah that will work. the pic is of them on the front wheel though...Might be a little different when you do the rears. I would go to phoenix wheel simuators site. you can buy a tool with the t handle there. just a suggestion.
John N.
Old 05-05-2013, 06:56 PM   #8
Iggy's Avatar
This might sound dumb but do you remove the crope caps that cover the nuts?
Is the tool in the draw to remove the caps or the nuts?
I never thought much about this but I think we need to know just in case we need a tire replaced.
I always thought they were just decorative caps which can be removed with a screwdriver and underneath was a nut.
My hubcaps are from Kaper II manuf.
Old 05-05-2013, 07:03 PM   #9
Im sorry I cant help you on that. I was thinking maybe my dually truck would be similar to your Georgetowns...It seems that they would be. On my truck I have simulators that cover the wheel. When I take off those 2 lugs where the vale extenders are the whole cover will slide out and you can get the the lugs for the actual wheel. Not sure if this is the same as what you got.
John N.
Old 05-05-2013, 08:14 PM   #10
jojo bamboo's Avatar
I Have a 2008 Georgetown and there are 3 "dummy" caps to take off/un-screw the false cover to get to the lug nuts.
The tool/ T handle that comes with the MH doesn't work if there on real tight.
When you go to the tire shop they will have the right size socket to take them off.
Do not let them use the air inpack wrench to do this.
Ask them to take them (3) off by hand, outherwise you'll be buying new ones.
.....take it from me.
jojo bamboo is offline   Reply With Quote
