Old 08-14-2015, 10:01 AM   #1
Turn Signal Camera
How do you remove the cover for the side turn signal camera ? Working on a fogging issue.
rdhodges is offline   Reply With Quote
Old 08-14-2015, 11:21 AM   #2
I think someone posted they pop off. Also someone else on the forum mentioned they traced the wire connections to the cameras under the hood, puller apart the connectors and lubed the connectors and that took care of the fogging. Plan on trying that myself. Let us know if you solve the fogging problem too.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 08-15-2015, 01:06 PM   #3
Read on another forum to put a small desiccant pack in the camera housing. Did that and ran a small bead of silicone around the gasket and cover. Next trip not for a few weeks, will let you know it it helped.
Old 09-30-2015, 02:00 PM   #4
Well back to the drawing board, it helped but not completely fixed.
More later........
Old 09-30-2015, 02:23 PM   #5
Which part helped but not fully? The moisture absorbent and silicone or pop off the lens cap and lubing connectors under the hood. Sounds like you got some progress either way.
sherman12
Old 09-30-2015, 03:48 PM   #6
I have not tried lubing the connectors under the hood, its next on my list !
Old 10-04-2015, 09:42 AM   #7
Coach 350's Avatar
From reading previous posts on this topic, insulating the wiring to the cameras in the engine area is the best fix,and corrects the problem.
Coach 350 is offline   Reply With Quote
Old 10-26-2015, 06:41 AM   #8
What do you use to insulate the wires?
surcy is offline   Reply With Quote
Old 10-29-2015, 09:42 AM   #9
Coach 350's Avatar
Go to Home Depot or lowes and look for pipe insulation. Cut and wrap wires.
