01-09-2017, 08:25 PM
Turn signals
The turn signals on my rig have decided to not work..Fuses under the dash and under the hood good...By the way, there isn't much room to get under the hood#! Also, hopefully Ford will find a way to make it more difficult to open the under hood fuse box !!!Any ideas on where else to look are appreciated.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
01-09-2017, 08:31 PM
can you clarify what you mean when you say they don't work? Not at all, or just one side vs the other? A little more detail would be great!
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
01-09-2017, 08:34 PM
Not at all..not a peep
01-09-2017, 08:35 PM
Do the 4 ways work?
Turn signal relay.
Is it plugged in?
01-09-2017, 08:37 PM
Originally Posted by Ford Idaho
Do the 4 ways work?
Turn signal relay.
Is it plugged in?
+1
01-09-2017, 08:53 PM
turn
Will check 4 ways..I have tried everything I can think of ,,only turn signals so far..
01-09-2017, 08:55 PM
Everything was working fine last Monday when we came home..Went for front end align today and no turn signals.
01-10-2017, 03:11 PM
4 ways work
01-10-2017, 05:51 PM
4 ways work
When turning does the turn signal switch self cancel?
If it does I would start looking around and under the front end to see if there is something that may have gotten undone by the frontend guy.
01-10-2017, 07:55 PM
turn
got it fixed.. A fuse was not making proper contact...Thanks for all!!!FYI, the owners manual doesn't really know which fuse is in each slot..
03-19-2017, 12:59 AM
Where was the fuse located? I am having same problem now and can't locate fuse.
2014 Georgetown 351DS
Chevy Colorado Crew
03-19-2017, 01:02 PM
Up under the dash..I think second row down about the middle. Good luck.
03-19-2017, 09:10 PM
Left Coast
A cheapo test light makes short work of finding a bad fuse....
03-19-2017, 09:35 PM
Just a little tight under there
03-19-2017, 09:36 PM
Left Coast
Sorry, can't help with that......lol
03-20-2017, 10:24 AM
I have a fuse tester with light that I used on all fuses under dash and none are bad. You press it on exposed ends of fuses.
I climbed, actually crawled back under there and pulled each fuse one at time to recheck. Found fuse in top left column position to be bent. The tabs were bent in opposite directions. I don't know how it's made contact for 3 years!
I bent the tabs back and inserted and bingo turn signals back working.
I guess the original installer had thumbed it in bending the tabs.
Thanks all!
Chevy Colorado Crew
03-20-2017, 11:50 AM
Glad you got it going.
03-20-2017, 12:13 PM
So does a wet finger and a good ground.
03-20-2017, 12:32 PM
Left Coast
Let's us know how that works out.....
03-22-2017, 06:35 AM
To work up front I remove the grill that gives me a lot more room. There are four bolts holding it in. Loosen the 4 bolts lift the grill up and it comes right out.
Jim & Pat
2016 Georgetown XL - 369DS
Tow Chevy Equinox
Blue ox and Brake buddy
