Old 06-18-2012, 07:49 PM   #1
Question TV antenna booster location
I can't locate my antenna booster location. Also can't figure out how to use my Executive DVD player on the main TV. I can get it to work on the bedroom TV.
steve patterson is offline   Reply With Quote
Old 06-18-2012, 08:02 PM   #2
TURBS's Avatar
Follow coax from tv to wall plate u should then find booster switch
Old 06-18-2012, 08:33 PM   #3
The tv is bolted at the bottom and it looks like a hinge at the top. If I unbolt it should it swing up so I can see behind it? I should mention this is a 2007 Georgetown 350 SE.
Old 06-18-2012, 09:05 PM   #4
bob213's Avatar
Look in the cupboards closest to the tv. It can't be far, as they wouldn't spend any extra money on coax to run it any distance. Where does tv get power? Could be around there?
May help others if you tell us what kind of Rv you have.
bob213 is offline   Reply With Quote
Old 06-22-2012, 12:03 PM   #5
Iggy's Avatar
Did you ever find it?
antenna
