Old 08-20-2013, 06:39 PM   #1
TV antenna on 335
As we get to know all of the ins and outs of our new 335, I have come to a question with which I'll need some help. This question revolves around the TV antenna. Does anyone know if there is a signal booster / amplifier?
While parked in our driveway I get no stations (we are about 40 minutes outside of Grand Rapids MI). Today I hooked up an inexpensive stand alone antenna intended for indoor home use. It has a small amplifier and immediately picked up 11 stations. I hooked up the roof antenna coax cable to the amplifier and was back to 0 stations. I cant believe that a $35 RCA indoor antenna from a local discount store is that much better than the roof top unit.
Am I missing something? Is there an on/off switch, circuit breaker, or other power supply of which I am unaware?
Jim Sullivan
Jim Sullivan is offline   Reply With Quote
Old 08-20-2013, 06:52 PM   #2
Tim & Lisa Trempert
Yes, there is an amplifier. It's a small push button on a white plate that has a 12v connector built in. Mine is in the upper right front cabinet. It hides behind the DVD player. There will be a green light when it's on. Crank up the TV antenna and make sure the switch box is on Antenna and not cable or satellite.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-20-2013, 08:44 PM   #3
Iggy's Avatar
This is what it looks like with a small button to turn on amp and a green led lights when on.
Probably in the back of the cabinet where the switch is loctaed for SAT , Antenna or Cable
Old 08-20-2013, 09:30 PM   #4
I found it! The set up is slightly different - the DVD player is in the radio, and the antenna is stationary always up - but the button is still there and it works. Back up to 11 stations.
Thanks for the responses!
Old 08-22-2013, 12:04 PM   #5
abjb's Avatar
I want one of these.
Wouldn't help Jim, but most of the rest of us could use it.
Winegard SensarPro TV Signal Meter - White - Winegard RFL-342 - Antenna Accessories - Camping World
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
antenna
