Old 11-19-2015, 11:49 AM   #1
tv cable splitter location
I have a 2012 Georgetown Forest River Class A 351 motorhome.My question is,where are the cable splitter conections located in this motorhome.i have good signal power from the outside cable source,but inside the signal drops,not allowing the router/modem to operate.but i believe the problem is at a splitter connection,but unable to locate,any help is greatly appreciated.
scooter54 is offline   Reply With Quote
Old 11-19-2015, 12:17 PM   #2
I have the same situation with a Rockwood 2703ws.. All my connections were loose and still haven't got a signal.
Rockwoodjoe is offline   Reply With Quote
Old 11-19-2015, 12:34 PM   #3
chrisbailey13's Avatar
On the 351 there should be at least 2 splitters.
One is in the forward compartment near the video source selector. if you have a forward TV, it is likely behind that TV.
The second one is likely under the drawers in the Bedroom, that one would supply the bunks and the bedroom TV.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 11-20-2015, 03:48 PM   #4
Cornelius's Avatar
Most regular TV splitters won't work with a cable modem. You will need to first install a special two port splitter that has outputs for TV and data. One output goes directly to the modem, and the TV labeled output can go to a second conventional TV splitter with ports for the number of TVs you are using. You can probably get one from your cable company. Here's what they look like and a typical (non-RV) installation:
Name:   modem splitter.jpg
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 11-21-2015, 04:57 PM   #5
Steelhorzz
Steelhorzz's Avatar
I found just about all of the AV connectors were loose, including those on the back of the DVD players and the TVs. Once I tightened them all, the reception was terrific!
2012 Georgetown 360DS Fire Mist
2007 PT Cruiser Auto-stick (4 wheel tow)
Remco Trans Pump /Super Springs Sumo Springs
Blue Ox Tow System / U.S. Gear Unified Tow Brake
Steelhorzz is offline   Reply With Quote
Old 11-21-2015, 09:22 PM   #6
On my 29RE 5er the splitter was located in BRm wall behind TV
Jim in Halifax is offline   Reply With Quote
cat, location
