Old 07-12-2015, 11:08 AM   #1
tilap's Avatar
Tv cabling
Ok I know it has been asked before, I went through most of if not all answers but I still can't find it. I use to wanna know only for personal development but now I need to fix my bedroom TV. While on antenna all TV in leaving room, outside worked perfectly but the one on the bedroom keep getting pixels. I am assuming something wrong with the cable from the splitter to the TV since all the other ones work. But I still can't find that stupid splitter. Anybody know where it is on a 377XL?
Denis, Forest river Georgetown XL 377 towing a 2014 Ford Explorer.
tilap is offline   Reply With Quote
Old 07-12-2015, 11:28 AM   #2
n1joh's Avatar
Look behind wall where the amp switch is
n1joh is offline   Reply With Quote
Old 07-12-2015, 11:31 AM   #3
Left Coast
Loose fittings.In my Rockwood, the splitter was in between 2 walls with no access.... had to create the access and use a wall plate to cover
Old 07-12-2015, 11:40 AM   #4
tilap's Avatar
N1joh not there I looked "...........bob how did u find it?
Old 07-12-2015, 12:30 PM   #5
Left Coast
Removed the antenna amp from wall, pulled easy on coax and there it was.....hole where amp was in wall created a fairly sharp bend in coax, which I didn't care for, so my Idea was to relocate splitter....my setup had enough slack to allow me to do that, but where I wanted it, had no access....new hole...access!
Old 07-12-2015, 12:51 PM   #6
tilap's Avatar
I looked behind the ant amp, did not see anything, I'll remove it again and try pulling and see if it will come.
Old 07-12-2015, 12:55 PM   #7
Left Coast
Mine wasn't sitting right there.....either.
Old 07-12-2015, 01:03 PM   #8
chrisbailey13's Avatar
That is usually caused by a loose fitting either at the splitter, TV, or amp. check all cable connections to ensure the coax is screwed in tightly.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 07-13-2015, 03:01 PM   #9
2006 Georgetown 340
Is it possible the coax cable goes bad over time?
I have a 2006 340 and when I connect to a park cable connection through the rear connector in the power compartment, I get the same pixeling. Connect direct to the back of the TV and its perfect.
compint is offline   Reply With Quote
