Originally Posted by Jim Sullivan
We are talking about a 2014 335. I added satellite to my RV toys (a Tailgater from Dish). The installer took better than 2.5 hours to install and get it working. The big problem, according to the installer, was that must be splitters in the wiring, interfering with the signal within the cable wiring in the RV. There is a satellite input in the second bay, but that did not allow a "clean" signal to the TV.
At any rate, we were able to cobble together a decent picture using the cable input in the back "basement" area.
I am looking for a wiring diagram of the cable/antenna/satellite feed for the 335 so I can make this work like it is supposed to. Anyone have access to the wiring diagram for the TV feeds on a 335?
Jim Sullivan
The actual SAT feed is on the roof under the vent cover that is located above the passengers side front. This vent cover is just a temp cover for future use if anyone wanted to add SAT dish on roof.
If you remove it you will find a coax end as well as 2 power leads that are not hooked up to any power yet.
Locate your antenna switch in one of your cabinets that SAYS Antenna, Cable and SAT.
This is where the SAT coax from the roof goes to.
If you have two TV yes you have a splitter and it is usually located behind the false cabinet wall where the 3 way switch is located. It will be attached to the output from the 3 way switch. You may be able to pull the coax and it may be close in the wall.
