Old 10-07-2014, 04:42 AM   #1
tilap's Avatar
Tv question
On my 377xl if i watch a dvd i can listen it on the home theatre system. When i watch tv on sat on antenna it doesn't play on the home theatre. Is that normal or is there a way to listen to it on the theatre system?
tilap is offline   Reply With Quote
Old 10-07-2014, 05:05 AM   #2
AquaMan's Avatar
Your tv may not hooked up to your sound system or you may have to turn off your internal tv speakers for the output to work going into your sound system. This can be done in the menu of your tv if you have the connections already.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-07-2014, 05:14 AM   #3
What year 377? Clarion radio? You may need to select "AUX IN" or "AV IN" on the Clarion unit, if that's what you have.
2013 Georgetown 350 XL
2009 Pontiac Vibe toad
chill960 is offline   Reply With Quote
Old 10-07-2014, 05:38 AM   #4
tilap's Avatar
2015 radio clarion, I tried aux in and av in. No joy
Old 10-07-2014, 08:03 AM   #5
chrisbailey13's Avatar
It only works from the TV in the Living room, not from the front TV.
Set the Radio to Aux 1 or Aux 2, depending on how your radio is set up.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 10-07-2014, 08:14 AM   #6
You need to look on the back of the television and see if the audio outputs are hooked up. If they are you will need to go into the setup menus to ensure sound is directed to them. You should also verify that the cables are hooked up on the audio system.
keith_h is offline   Reply With Quote
Old 10-07-2014, 09:10 AM   #7
tilap's Avatar
Thanks Keith will try that
Old 10-12-2014, 12:58 AM   #8
If your sat receiver is close, run two rca cables from the audio output on the receiver to the aux input on your surround sound system and turn the surround sound on with the satellite and viola! Just turn the volume on your TV down, and control the volume through the surround sound system.
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
