Old 10-12-2019, 12:10 PM   #1
TV removal
Please, can someone tell me how to remove the front TV from a 2006 Georgetown. It extends into the ceiling and I haven't been able to figure out how to remove it.
jojob is offline   Reply With Quote
Old 10-13-2019, 04:29 PM   #2
This is how it came out on an 08 Georgetown. .On the underside of the tv their is a thumbnail screw visibly sticking out. Unscrew this and the tv should swing out and the back mount can be seen. From their each tv might be different in number of mounting screws used. A helper is needed to hold the old tv as it will be a lot heavier than the new replacement. Used the original mount off old tv and it took a little engineering in order for the new tv to fit. The new mounting was a lot easier an the new tv is very light compared to the old one.
margesdiamond is offline   Reply With Quote
