If yours is like mine there is a release. I have a 2016 Surveyor so likely similar. I had a similar struggle getting it off until I discovered the release which has a short woven tether attached to it that got tangled in the wires so I didn't see it. With a flashlight and mirror, since it's tight fitting, I finally got to it. Once the release is pulled, I pull out on the bottom to disengage, then lift up, comes right off. As for the hdmi, my tv has it but the receiver/control does not. The TV is regular current and the receiver is 12 volt, as are the speakers, so I just got higher quality component cables and finally got everything to work. Changed from Jensen to Visio TV.
Now I'm careful that the release tether, which hangs down when not tangled, is accessible to release the tv. My next project is to replace with a 41 or 42 inch tv.
