Old 09-21-2015, 08:14 PM   #1
TV wiring
I can't figure out the TV wiring .
Can anyone help me out with a diagram for the 335DS Georgetown
Something is not set up wright, sure would appreciate it.
Thanks Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 09-22-2015, 11:48 AM   #2
Iggy's Avatar
We would like to help but could you be more specific about what issues you have?
In general terms you have one cable that you attach in one of your compartments that you attach campground TV cable.
You have a roof antenna cable that is run by a 12 volt amplifier. ( You must turn on at the small control panel in back of your cabinet.
You also have a Satellite cable from the roof for future Satellite dish on the roof.
All the coax cables go to a switch box that you select ROOF ANTENNA, CAMPGROUND CABLE or SATELLITE DISH ON ROOF.
You also must have the TV set menu set to select the proper input source or you will not receive anything. You also need to do a TV channel scan each time you hook up to the roof or campground cable.
Hope this give you a little better understanding of what you ay have
Good luck.
Old 09-22-2015, 03:04 PM   #3
Ok here is what's happening ,when I put cable wire from control box in sat using the outside cable connection.And then the output from controlbox for TV to the sat box ,both tvs show same stations one should be sat and other should be ant ,so this is the problem.
Hope this makes sense .
Don
Old 09-22-2015, 08:23 PM   #4
bubbles's Avatar
I believe what ever you have selected at the TV input select box (CABLE/ANT/SAT) both TV's will have the same input because the rear TV is connected via a splitter after the afore mentioned input select box. This is the way my GT is wired from the factory. You would need to find that splitter and disconnect the rear TV's coax and route it to a separate select box and parallel all the input viewing options to the new select box to be able to set the rear TV up for alternate viewing.
Old 09-22-2015, 08:54 PM   #5
Anyone know we're the splitter is on my year and model?
Thanks Don
Old 09-23-2015, 07:15 AM   #6
chrisbailey13's Avatar
Thanks Don
I am not 100% sure on your model, but it is likely behind the TV that is closest to the Switch box (the one in the living room).
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 09-25-2015, 02:55 PM   #7
Anyone know for sure we're the splitter is on the 335DS
Thanks Don
Old 09-25-2015, 04:46 PM   #8
Forest river says it depends on who wired it that day. Good luck
bt1223 is offline   Reply With Quote
Old 09-25-2015, 07:17 PM   #9
Wow !! Why would they use a splitter anyway who want watch the same channel on every TV.
Don
Old 09-25-2015, 07:46 PM   #10
bubbles's Avatar
Don
They don't have to watch the same channel if the input is park cable or over the air antenna, just have to watch the programming from the same source. Sat is a whole different ball game.
wiring
