Old 02-15-2016, 09:49 AM   #1
TV's
In a Forest River 364TS does the outside TV play DVD's from the player inside the coach? In fact does that DVD player transmit to any other TV in the coach?
How about cable? Do all the TV's have to watch the same cable channel when you are hooked up to the cable provided by the park or can they all watch different channels?
Does the out side TV get a cable signal?
I am thinking they are all set up for satellite and we don't do satellite service in our coach.
RVCrazy is offline   Reply With Quote
Old 02-15-2016, 06:36 PM   #2
My 378 xl has a Vizio smart tv and a am/fm dvd player in the outside compartment. Input options are selected through the menu on the tv remote. Selecting cable allows the tv to get signal from the park cable connection where you choose a channel independently from whats playing inside the rv. You can select to play a dvd on the outside player. You can also access the HD antenna as well. Assuming you have a similair set up this should help.
jeffv003 is offline   Reply With Quote
Old 02-15-2016, 06:56 PM   #3
chrisbailey13's Avatar
No, the outside TV does not get signal from inside DVD player
Living room TV's should receive video from the DVD player by selecting the one of the line level inputs on the TV.
The bunk TV's have their own DVD players and do not receive signals from the forward DVD player
Each TV can watch different channels when connected to park cable, but if you are using satellite, you will all have to watch the same channel unless you have a multi tuner receiver.
Yes
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 02-15-2016, 07:25 PM   #4
AquaMan's Avatar
I set up my satellite receiver through the front coax switch, so all tv's will get the same signal. This is rarely an issue for us. Kids will watch their own movies, I have separate media players connected to the bunk tv's that they can choose from about 200+ movies without having the DVDs. I mainly wanted the satellite for the outside and bedroom TVs while camping, and the front TV while in motion.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-22-2016, 10:53 AM   #5
So do the players in the bunks get park cable?
Old 02-22-2016, 11:08 AM   #6
Yes they do
Old 02-22-2016, 11:09 AM   #7
AquaMan's Avatar
I would assume that they do, since I was able to run the satellite to them through the front selector box. What I noticed when we got ours, was the the coax was disconnected from both bunk tvs. It was a right angle push on, and was a bit loose. Had to tighten it up a bit to get one of them to stay on.
