Old 05-23-2013, 09:03 AM   #1
Under awning lights
I have read through the thread on awning lights but I would like to know where folks are pulling the DC power from when doing a permanent install on a Georgetown motorhome. Pics would greatly be appreciated.
Thanks in advance and have a wonderful Memorial Day holiday and be safe.
Marty
2007 Georgetown XL 378
"EZE-TOW" Dolly
2010 Toyota Prius
mkaminski is offline   Reply With Quote
Old 05-27-2013, 07:58 PM   #2
I was hoping someone had installed lights under their awning and would share some pics of how they did the wiring.
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-27-2013, 10:03 PM   #3
Phat Phrog Stunt Crew
awwall's Avatar
Marty, I will try and get you a pic tomorrow. Essentially I ran my led strip along the edge back at the RV. As I passed over the top of the outside door light, I installed a "T" in the lights and dropped a connector down to the existing light fixture. Drilled a small hole in the top and fed wires inside, Connect to the existing bulb socket for the 12v supply. My leds operate when I turn on the porch light. Make sure all connections are water proofed.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-28-2013, 08:21 AM   #4
That sounds great!! Pics would be nice. Did you order the "T" connector or make it.
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-28-2013, 08:34 AM   #5
Wayne,
Who did you purchase your lights from?
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-28-2013, 09:07 AM   #6
awwall's Avatar
Marty, I ordered the "T". Will get you details on the "T" and lights when I post pics.
FROG Member
Old 05-28-2013, 10:47 AM   #7
awwall's Avatar
Here is pic of tie in to outside light. Still looking for some wire molding small enough for it. couple of dabs of silicon for right now.
Here is where I bought the parts. For sealer, I used liquid tape.
"T"
4pin Solderless Joiner "T" Type Connector Coupler for 10mm PCB RGB LED Strip | eBay
"Conector"
1M RGB Extension Cable Wire for 5050 LED Strip 4 Pins Needle Male Connectors | eBay
"Lights"
5M 5050 RGB IP65 Waterproof SMD 300 LED Strips Light 24 44Key IR 12V 5A Power | eBay
FROG Member
Old 05-28-2013, 11:28 AM   #8
Wayne,
Thanks for the pics and links. I'm ready to do mine now.
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-28-2013, 05:50 PM   #9
Has anyone tried these? If so can they be cut to length?
5M 5050 RGB Dream Color 6803 IC LED Strip Light Waterproof 133 Change RF Rmote | eBay
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
Old 05-29-2013, 12:24 PM   #10
Wayne,
Where did you mount the control box?
Marty
"EZE-TOW" Dolly
2010 Toyota Prius
