Old 04-03-2013, 09:17 PM   #1
Unknown Switch
I have 2014 Georgetown 351 with a switch next to the water pump switch that is labeled ARTIC (on top) and PAC (on the bottom). Does anybody know what this switch is for or what is it used for?
CTMDP is offline   Reply With Quote
Old 04-03-2013, 09:24 PM   #2
Iggy's Avatar
Hi and welcome
If you plan on going into a cold area that drops below 40 degrees you turn this on when at a campsite.
It will put 12 volts DC from house batteries to electric heat pads on your grey and black storage tanks as well as many water elbows underneath.
Their is many around the water entry compartment. It looks like tin foil with wires on it. You will also find them at the back of your refrigerator if you have an ice maker or water in the door.
The pads are controlled by a thermostat that turns them on if the temp get around 40 degrees.
Hope this helps
Old 04-03-2013, 10:40 PM   #3
I had an idea that was it but was not sure how or what it was hooked up to. More important there is no mention of this in any of the manuals. Thanks so much your reply, it was greatly appreciated.
Old 04-03-2013, 10:54 PM   #4
Iggy's Avatar
FYI mine is on a 20 amp fuse in the DC control panel.
Many others believe it is only pads on the black and grey tanks but in mine I have many locations usually athe the water elbows that are wrapped with the tin foil pads. I actually used it once and I didn't get anything frozen.
Iggy
Old 04-04-2013, 06:19 AM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
The info about the Artic Pak is on a seperate sheet which I had to request from FR. What I received looked like the 10,000,000th copy of a instruction sheet. I planned on retyping it but have never gotten around to it. I'll try to get it done and post it in pdf form here in the next couple days.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 04-04-2013, 08:10 AM   #6
Iggy's Avatar
Oooh... That willbe greatly appreciated.
Hope you get a chance to retype it.
Iggy
Old 04-04-2013, 08:30 AM   #7
That would be great if you could re-type it. Thanks!!! Did FR ever say why its not in any of their manuals? Thanks for all the responses.
Old 04-04-2013, 08:39 AM   #8
cfsoistman's Avatar
No they never explained why. I guess since it's an option they didn't include it in the Generic Motorhome Manual they have. In our case it was listed as a "Forced Option" in the brochure for that year. Guess its just another oxy-moron like Jumbo Shrimp and Maryland "The Free State"
Mike Burns, retired from FR, sent the copy I have to me.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-04-2013, 08:48 AM   #9
cfsoistman's Avatar
Iggy
Sent myself an email to do it tonight. Now I just have to remember to check my email when I get home I should scan the original and post it in case anyone wants the Official Reference Sheet
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-04-2013, 10:31 AM   #10
cfsoistman's Avatar
ForestRiverOwnersManual-Motorized.pdf
Just found this on FR site, free downloads. Check page 47 for info about the Heating Pads. I will still retype what I have as well at home.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
