This is what I replace my Jack Knife Couch with. These are made by Recpro full size modular recliners with a center console 3 pieces that attach together. Im not sure I would install these if I where to do it again because they took some modification to get them to fit on the raised slide. so they sit about 4" taller due to the raised slide. Not a huge deal and they are soooo comfortable!! I would suggest you may want to get recliners from the manufacturer that fit your rv ?unless your prety handy is fabricating. I believe the total cost for the 3 pieces was around $800.00 Amazon and about 25.00 worth if hardware and fasteners to modify the slide to get them to fit on the slid
