Old 08-02-2012, 03:21 PM   #11
Send a message via Skype™ to Falcon35
I was at a seminar where the presenter told us to be sure to regularly exercise our generator. He suggested a good way to do that was to start you generated and turn on both AC's for one half an hour as you go down the road.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 08-03-2012, 10:53 AM   #12
bend302's Avatar
I regularly run my generator and A/C while driving and do so mainly to exercise the genny. I had a substantial repair bill when my Generator carb had to be removed and cleaned because the previous owner failed to run it enough. 144 hours in 5 years...
I have also heard the rumor that running the roof A/C & generator was cheaper than engine A/C but really don't notice the difference. Would like someone knowledgeable to comment.
And, yes, the battery charge rate is faster with both the engine alternator and the generator running.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 08-03-2012, 11:24 AM   #13
Iggy's Avatar
I run my generator regularly but need to do more.
I like the idea of starting the 2 AC units on generator 30 minutes prior to arriving at my campground destination. Here in Arizona that means it will be cooler faster.
Great idea to cool everything and exercise the generator.
Oh don't forget to read your manuals on changing oil and filter.
Mine is 25-30 hours of run time but for a quart of oil and a filter change regularly will make your engine last longer.
Thanks for a great idea!
Question.
Does the Georgetown have a valve to shut off the gas to the generator so you can drain the carborator when in storage for extended periods of time? That way you won't get varnish buildup in the carb.
Iggy is online now   Reply With Quote
Old 08-03-2012, 11:40 AM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
Originally Posted by Iggy View Post
Question.
I would think there would be something in line since the generator fuel supply comes from the coach gas tank. I can't imagine if service was needed the dealership would just pinch the line off or at least I'd hope they wouldn't. Looks like I'm going to be climbing under the coach this evening to look for it. I can attest that the generator will shut off once you get down just below 1/4 tank of fuel. Found this out first hand last summer going to Myrtle Beach. Best part was it stopped just as I pulled into the gas station to fuel up.
Once I filled my tank and cranked the generator it started right up. The AC unit wasn't off long enough for a temperature change in the coach.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 08-03-2012, 12:33 PM   #15
I always put in STA-BIL fuel additive to any gas motor if it will not be run for 4 weeks or longer. The formulation of todays gas allows it to go bad in little as 3 weeks. I've never had any problems while using STA-BIL even when we had a toy hauler that would sit for 3 to 4 months with out running the generator. It would always start up in 2 tries or less. They key is to run the engine for 15 to 20 minutes to allow it get into the entire system.
concours14 is offline   Reply With Quote
Old 08-03-2012, 12:52 PM   #16
MotocrossCamper's Avatar
You really don't want to drain your carb for storage if you can help it. It should be started every 2 weeks even in the off season.
If you do drain it you don't need a shut off for the fuel, the generator has its own fuel pump so fuel will not just keep flowing when you empty the carb. Only time it flows is when it's running.
MotocrossCamper is offline   Reply With Quote
Old 08-03-2012, 01:29 PM   #17
jsutherl's Avatar
Question.
Mine does not. I removed my generator once and I used some vice-grips to clamp the fuel line. It's on my list of things to add though.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 08-03-2012, 02:39 PM   #18
cfsoistman's Avatar
Thanks jsuther l, I didn't think there was a valve under there and now I don't have to slide under to look.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-03-2012, 06:23 PM   #19
Freds342's Avatar
I will start my Onan 5500 today at 5:00pm, and won't shut it off until Monday morning, unless the outside temps get below 75 (unlikely during this no-rain, high humidity weather!).
We're going to Lake Isabella, and are parking along the lake shore with no services. My wife's Myasthaenia Gravis condition allows for a narrow range of ambient temps, and I'm thankful for the ability to run the genny where we stay.
On previous trips, with outside temps in the 100-105 range, the MoHo stays a nice 75 degrees at .6-GPH of genny use.
Considering that the CG costs $7.00/night with the Senior Pass, and we're right on the lake, it ain't a bad tradeoff!
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
air conditioner
