Old 08-19-2015, 05:37 AM   #11
cjd10's Avatar
Originally Posted by B and B View Post
Maybe the battery disconnect is pulled?? PDI maybe mentioned a battery switch somewhere.
Agree. Battery disconnect on a new 351 is down low on the left as you come in the entry door.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 08-19-2015, 06:41 AM   #12
chrisbailey13's Avatar
If it is the battery switch, you would also not have interior lights, correct? and how does the battery switch affect the inverter, or is it wired directly to the Battery terminals, bypassing the swtich?
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 08-19-2015, 11:46 AM   #13
oldsmasma's Avatar
Surely one of the greatest motorhome benefits IMO. So convenient to use the "facilities" including washing up. Also easy to even make a quick snack for DH and I while we ramble on. Also very nice to have some fresh water in the tank when stuck in gridlock.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 08-19-2015, 11:53 AM   #14
GABoy's Avatar
Originally Posted by philthy99 View Post
I have a georgetown 351... How do u use the water as u are driving?
I've tried the water pump... Seems to work with the generator, does it work without the genny?
Also, with dish network satellite... Do u plug into the back, storage Area of the RV, and then plug in the dish box to the front of the RV in the cabinet? And can you view dish on all of the TVs or only one TV?
In our 351 I always fill some water from home in the fresh water tank before each trip. I leave water pump switched on during travel. This lets fridge make ice while rolling. Another great advantage that I didn't think of when we moved up to class A from TT is I don't stop till I need to take a break now. DW and DK go potty, wash hands and get drinks as needed or wanted.
No more "I got to potty" and having to pull over every 30 minutes!
Also have plenty of ice for a cold drink once set up at destination!
Happy travels!
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 08-19-2015, 02:06 PM   #15
Sharon455's Avatar
Originally Posted by chrisbailey13 View Post
How do you wash your hands after you flush? Seems like it would be a lot easier to put 5-10 gallons of water in the onboard fresh water storage.
1. We do carry water in the FW tank.
2. While traveling, we use Wet Ones and hand sanitizer. Our kitchen sink holds out knife block in one side and the drainer w/ sponges in the other. Turning on the water in the bathroom could get quite splashy driving down some of the roads here in AZ. Besides, we don't keep the water heater running while driving and cold water doesn't do much to kill germs.
3. Our 7 year-old granddaughter has trouble with the single pedal to both fill and flush while hooked up, much easier to fill it for her and then hand her a Wet One after she flushes.
Happiness is just a ride away!
Sharon455 is offline   Reply With Quote
Old 08-19-2015, 02:22 PM   #16
dougpatz's Avatar
I think the water question has been thoroughly discussed.
Your DISH question-With our mobile King Dome, both TVs can watch different programs, but they have to be on the same satellite, and the satellite selection is done by the main TV. You will learn what programs come from what satellites, over time. When I am watching in the bedroom, and hear the "ugh" of the DISH moving, I know I am losing my program.
Patti Z.
2011 Lexington 283
Husband - Doug
Springer Spaniel - Sheldon
dougpatz is offline   Reply With Quote
Old 08-19-2015, 07:35 PM   #17
jkoenig24
I don't have a Georgetown but, I thought water pumps were 12VDC which would always run off a battery that had a charge.
jkoenig24 is offline   Reply With Quote
Old 08-19-2015, 08:17 PM   #18
The switch for the Battery Disconnect / Connect at the stairs, by the door are "on"... so that is not the issue. I have water, 1/4 tank or so, but it won't work unless shore power or Genny are on.
Thanks for the responses. Hopefully I can get the Satellite to work this weekend.
philthy99 is offline   Reply With Quote
Old 08-19-2015, 08:23 PM   #19
Sounds like you need a visit to the repair shop for the water pump issue.
Good luck on the satellite.
Old 08-19-2015, 09:27 PM   #20
Have you checked the inline fuse at the water pump?
You can also run a hot wire to the pump and see if it work there.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
water
