Old 05-24-2018, 02:47 PM   #1
Iggy's Avatar
V-10 Engine Battery Replacement Time
OK I know I start a lot of threads but this one I need help with.
I have been very lucky with my Ford Engine Battery and it is original when the rig was build by Ford which was Oct 2011.
So I figure the battery this Oct it will be 7 years old and probably 8 years old.
So I was looking for my replacement for a Category/Class 65 battery
750 Cold Cranking Amps or 850CCA
Sam's Club Duracell 65 with 850 cca $105 - $20 until June 3rd =$85
Walmart has a 750 cca for $93
Walmart has 3 year replacement and then prorated for 2 more
Sam's Club Duracell warrantee end at 3 years.
So what do you think about the two battery brands?
Should I go and spend $179 for a Ford Interstate replacement?
Your thoughts and opinions are needed.
PS Take a look at the prices of the Interstate batteries. WOW!
Iggy is online now   Reply With Quote
Old 05-24-2018, 03:04 PM   #2
Iggy's Avatar
Her eis the Costco Interstate Battery Price for a Class 65 Battery.
Old 05-24-2018, 07:32 PM   #3
Our chassis battery failed in Yellowstone on July 4 2016. We left Yellowstone on the 9th and stopped at the first Autozone I could find. Bought a new battery... installed for $109...I think its a Duramax. I had one in the toad that lasted 8 years... the motorhome was built in Aug 2009 so the original Motorcraft battery was almost 7 yrs old.
I used Interstate at work for our truck fleet and was not impressed with their pricing or longevity, but their service was outstanding.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 16 days
mogman is offline   Reply With Quote
Old 05-24-2018, 07:42 PM   #4
Iggy's Avatar
Thanks John for your story. I still haven't decided who's I'll buy.
For the dollar amount at this moment I'm thinking Sam's Club Duracell for the $$ and amps. 3 year replacement warranty is OK for me.
So I figure $105 - $20 = $85 + $7 tax = $92 is reasonable
Old 05-25-2018, 07:13 AM   #5
As you know there has to be a reason for the price difference.
1. It might be because of the seller's replacement cost if it goes out early.
2. Check the weight of the different batteries. I bet the cheaper batteries will weigh less.
3. Even if the cheaper battery last only 4 maybe 5 years your will be out about the same dollars per year, maybe even a little ahead but then again, maybe stranded when it does fail.
Like anything it is a gamble.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 05-25-2018, 01:27 PM   #6
I really do not care who makes the battery. I live in Idaho, batteries after 5 years usually do not make it though the winter, and will quit at the worst times when the night before was 10 or 15 below zero. That is why after 5 years, need it or not, I change them out.
Radio7 is offline   Reply With Quote
Old 05-25-2018, 01:44 PM   #7
I’ve had fair luck with Walmart batteries but then again we live in Wisconsin so we replace batteries every 5 years
Me advtage to Walmart if your traveling and do have the battery die under warranty chances are you will be closer to a Walmart then a costco
2011 gray wolf 25rb
Jmkjr72 is offline   Reply With Quote
Old 05-25-2018, 02:08 PM   #8
A32Deuce's Avatar
After getting over 15 years out of an Optima Battery, I have them in every vehicle we own except the RV. Have them for the house bats not chassis yet!
A32Deuce is offline   Reply With Quote
Old 05-25-2018, 02:23 PM   #9
bend302's Avatar
My Ford OEM batty failed last fall. I used the battery interconnect to start the engine and get it home. The I pulled it and went to Batteries + for a new Duracell. Work good so far.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 05-25-2018, 02:23 PM   #10
lswartz's Avatar
I traded my Ford Club Wagon with a V10 after 10 years, never bought a new battery. Maybe have it load tested & see what kind of shape it is in. Some suggest using a hydrometer for a better test.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
battery, replacement
