Old 12-14-2012, 08:43 PM   #21
Brian,
All this talk about the problem with the valve stems has me wondering, what does Chevy 4500 chassis have for stems. We will be picking up our 2860 the 28th and driving it 900 miles back to Colorado Springs. Do not think the wifie would like it if tire parts are flying onto the prairie.
Wildkats66 is offline   Reply With Quote
Old 12-15-2012, 07:00 AM   #22
GM
bclemens's Avatar
We're using the Air Flexx non pressurized. We've had no issues with those.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 12-15-2012, 09:51 AM   #23
Thanks for the quick response. You going to be at the Jan RV show in Denver..might have to drop by and say thanks
Old 12-15-2012, 12:38 PM   #24
phat phrog stunt crew
here ya go folks. my boss ran these on his trucks/trailers when i was driving otr. just a quick walk around to check tire pressure. no more messing around with pressure gauge tring to check inside tires. easy peezy.
Link - Cat's Eye, Tire Pressure Maintenance System
about 200 per dual wheel position, so you motor home guys will only be out around 400 bucks, or about the price of a new tire.
dwaynerz is offline   Reply With Quote
Old 12-15-2012, 01:57 PM   #25
Tim & Lisa Trempert
My valve stem nuts (that hold them in the bracket that is riveted to the hubcap) keep rusting. I've received free replacements from the vendor, but they still rust. Has anyone been able to find stainless steel valve stem nuts?
Thanks.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 12-17-2012, 07:51 AM   #26
GM
bclemens's Avatar
I'll be there. Not sure which days yet.
Old 12-17-2012, 05:40 PM   #27
When you get it pinned down let us know.
Thanks for everything
Old 12-30-2012, 05:29 PM   #28
hazbunch's Avatar
I couldn't stand the valve extensions either. I purchased a kit from Duallyvalves.com, it comes with the extensions and 1.75 inch stabilizers for the inside wheel, plus the outside 90 degree valve stem. I took it to a tire shop to have them installed. It has made it so much easier to check tires psi.
hazbunch is offline   Reply With Quote
Old 12-30-2012, 06:00 PM   #29
Villa Estate 392FLFB
The_Stuff's Avatar
the extenders for the inner duals worked for me but the ones for the outter duals were a pos and kept making them go flat..
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 12-31-2012, 06:11 PM   #30
Are tire pressure monitors able to go on the extensions?
reubenray is offline   Reply With Quote
