Old 07-07-2013, 11:40 AM   #1
RudysWorld's Avatar
Vent clogged or obstructed?
When emptying the gray tank I noticed that it will flow fairly well then slow, followed by a whoosh sound and then drain completely. Also, after dumping the black tank I am noticing an odor. After reading through the forum I thought it might be a vent clog causing both issues.
How would I clear the vent?
If you think my diagnosis is off what do you think it would be.
Thanks to all!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 07-13-2013, 01:35 PM   #2
Tim & Lisa Trempert
Thanks to all!
Regarding the gray water tank...if you get a clear connector, you will see that you hear the water flowing until the discharge tube is completely full as it can't keep up with the flow out of the tank. No air = no noise. Then, once the tank is empty you'll hear the whoosh sound. Nothing is wrong. This tends to happen most when the discharge hose is has to run uphill into the sewer and is only slightly below the holding tank discharge level.
Your black may be the same issue. I would highly suggest a clear connector as you can also tell when your black backwash cleaner has completed its job.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-13-2013, 02:48 PM   #3
puff's Avatar
what Tim said..!..x2
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 07-14-2013, 07:13 AM   #4
Send a message via Skype™ to Falcon35
Originally Posted by trempert View Post
regarding the gray water tank...if you get a clear connector, you will see that you hear the water flowing until the discharge tube is completely full as it can't keep up with the flow out of the tank. No air = no noise. Then, once the tank is empty you'll hear the whoosh sound. Nothing is wrong. This tends to happen most when the discharge hose is has to run uphill into the sewer and is only slightly below the holding tank discharge level.
x 3
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 07-14-2013, 07:29 AM   #5
Herk7769's Avatar
One add. From your post I think you are under the impression that there is only one vent. In fact, each holding tank has its own vent.
That vent is 1 1/2 inch tubing. The dump valve is a 3 inch outlet. A full gray tank can output more water faster than air can be replaced. This will continue, causing a slight vacuum in the holding tank, until air can equalize when the sewer pipes get filled and the rate of exit slows down.
You might even see the "burps" in water flow with a clear elbow.
HAM CALLSIGN - KC3FFW
Old 07-14-2013, 07:48 AM   #6
The rush of grey water can even pull the water from the 'P' traps in the sink and lavatory and does quite often allowing the smell to permeate into the coach/trailer. I usually will go back in the trailer and run a little water in the sink & lavatory to fill the traps especially if the trailer is not going to be used for a few days.
Old 07-14-2013, 07:55 AM   #7
Herk7769's Avatar
Excellent point. Odors in the camper can often be traced back to an empty P trap in the shower after travel. Gray water... smells.
Old 07-14-2013, 09:06 AM   #8
RudysWorld's Avatar
Odor probably caused by gray tank sucking water from P trap. I am a first time RVer and just assumed vent would keep up when dumping. After recommendations I think I will get a clear extension to place at RV. I have a clear elbow at CG sewer connection but during black tank flush there doesn't seem to be enough flow to show well. Clear extension may give a better view during flush.
Thanks to All!
Old 07-14-2013, 09:15 AM   #9
I discovered it the hard way by emptying the tanks and just towing home, emptying the camper and leaving it closed up for 2 weeks. When we went in the camper to load for another trip, the odor just about knocked us back out the door. Didn't take long to figure out where it was coming from as the sink drain was right by the door. Cup of water down the drain and the smell quit coming from there. Took several days with fans blowing to get rid of the after effects of my ignorance.
