Old 01-12-2019, 12:34 PM   #1
TomW's Avatar
Vinyl ceiling
My 2011 Georgetown vinyl ceiling is coming loose, anyone have a fix for this?
TomW is offline   Reply With Quote
Old 01-12-2019, 09:04 PM   #2
Welcome to the club..I've been fighting it for 4 years.
Best I found was spray glue, then put up some foam strips and plywood, all held up to the ceiling with 2x4 props. In some areas the ceiling vinyl is shrinking so it won't go under the strips anymore.
Now the seats and dinette are starting to flake off. By the time we sell this RV it will be a junker!!
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days
mogman is offline   Reply With Quote
Old 01-15-2019, 09:01 AM   #3
JimF's Avatar
We also have a 2011 unit, a 378, and have had the same problem. There have been way to many posts on this subject as it was a common problem for that year units. The factory had use a faulty glue. Personally I pulled the vinyl out from under the plastic tract and the sidewall then used a Heavy Duty High temperature headline spray adhesive I purchased at Cloth World. Sprayed the back per instructions and used a squeegee to smooth it out, tucked in back under the plastic trim and sidewall. That was 4 or 5 years ago and no problem since. BTW, it took quite a while to do the job I learned some new words while doing it, but it worked. Good luck .
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
