Old 04-05-2016, 01:04 PM   #1
Want to tow a RZR on a trailer
Will I need a trailer power brake up at my dash or is there one built in or is it safe to tow without? I am in AZ and will be heading up in the mountains.
Thank you,
denveer is offline   Reply With Quote
Old 04-05-2016, 01:23 PM   #2
Yes I highly suggest using one, it's pre wired you will need the Ford plug and a brake controller, I use prodigy. The plug is under the dash, it's plugged in to a plug going up to dash, disconnect that and plug and play.
Cheapest cable I found..
https://www.rvupgradestore.com/Tekon...-p/17-0051.htm
Kevin M. is offline   Reply With Quote
trailer
