Old 07-25-2015, 10:05 PM   #11
2006 Georgetown 340
I would like to install fog lights in our 2006 FR Georgetown and found the wires under the hood already there. I have 2 switch plates in my dash and have 2 factory harness connections behind the plate. I assume that one is for the fog lights and one for dash fans? Does anyone know which would be which or what these might go to?
ID:	84182   Click image for larger version
compint is offline   Reply With Quote
Old 07-27-2015, 10:44 PM   #12
Just installed a set on my 2006 340 TS. That is the connection for the fog lights. Mine already had the switch and was all wired except for the +12. Could not find a spare +12 under the dash so ran a fused line from the battery, was able to push it thru one of the wire looms already going thru the firewall. Got the lights for $40 from my local auto parts store.
Name:	ImageUploadedByForest River Forums1438054152.906410.jpg
ID:	84353   Click image for larger version
Name:	ImageUploadedByForest River Forums1438054536.457407.jpg
2006 Georgetown 340 TS
Hoverdave is offline   Reply With Quote
Old 08-23-2015, 06:59 PM   #13
2006 Georgetown 340
Fog Light Upgrade
Working on installing fog lights in our 2006 Georgetown 340 TS.
1. I picked up a Carling switch to plug into the factory harness behind the dash
2. I picked up the factory for lights Hella model 1300
3. I confirmed there is a wire harness at each fog light location under the hood.
4. I see that there is a "Hella" relay plugged into the factory wire harness
It would seem all I would have to do is to plug into the fog lights to the wire harness. When I tested, I am not getting anything. Is there something else I need to do?
The Hella 1300 lights came with another relay. Would these lights need to work with this relay?
Thanks in advance....
Old 08-23-2015, 07:06 PM   #14
I had to add a 12 volt line from the battery to the switch.
Old 08-23-2015, 07:34 PM   #15
2006 Georgetown 340
What wire did you connect into on the back of the switch? When I at the back of all of the switches, I do not see a power wire in any of the switches on the back of the panel.
Did you have a HELLA factory relay switch in your harness as well?
Thanks,
Old 08-23-2015, 08:19 PM   #16
Just double checked, it was the large gauge red wire to the back of the factory relay labeled CPF. If you follow this wire you are likely to find it is not connected as mine was. Was able to push this thru a wire loom that already went thru the firewall and connected to the battery. Installed a 15 amp fuse in line at the battery, see photo in my original reply. Click image for larger version
Name:	ImageUploadedByForest River Forums1440379144.439753.jpg
ID:	86657Click image for larger version
Name:	ImageUploadedByForest River Forums1440379163.181062.jpg
Old 08-23-2015, 08:36 PM   #17
2006 Georgetown 340
Smile
When you say factory relay, do you mean the factory harness at the dash? I have the same but it only has 4 wires and no red wires. I do have a HELLA relay under the hood that is connected to the wire harness that has 3 red wires coming from it.
Thanks in advance.
Old 08-23-2015, 08:41 PM   #18
My relay is in the dash, I am pointing to the wire that needs to be +12. The relay you have under the hood might be the same.
Old 08-23-2015, 08:46 PM   #19
2006 Georgetown 340
I will check the red wire and where it might go. Basically though when you connected that wire, that powered your wire harness that controls the lights?
Old 08-24-2015, 12:13 AM   #20
Yes
light
