Old 08-12-2012, 12:27 PM   #1
Phat Phrog Stunt Crew
awwall's Avatar
Warning on Valve Extenders from Factory
My Georgetown came from the factory with valve extenders on the inner rear duallies. Yesterday, for the first time since bringing it home from dealer, I decided to check tire pressures. Found that one of the extenders was cross threaded on and not bottomed out. I could get no pressure reading. Decided to remove extender, but all it does is turn and will not come off.
Will be headed to tire shop tomorrow to remove tires and see what is necessary to repair valve stem. Probably is ruined.
If you are picking up a new coach, make the dealer check these for you!!
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 08-12-2012, 03:33 PM   #2
It's a new motorhome, why would you take it to a tire shop and pay for it? Take it back to the dealer. If it needs to go to a tire shop then the dealer/Forest River can make the arrangments and pay for it.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 08-12-2012, 03:50 PM   #3
TURBS's Avatar
X2
The valve stem is inserted from the inside of the rim you cannot remove it from outside with tire on.
The nut being cross threaded shouldn't have nothing to do with checking or installing air.
I agree talk to the dealer about it first.
Ron
Old 08-13-2012, 08:38 AM   #4
awwall's Avatar
It is over 100 miles to my dealer. I am afraid to drive this distance with this extender in this condition.
F1, this is an extender, not the valve stem, that is cross threaded.
FROG Member
Old 08-13-2012, 08:48 AM   #5
TURBS's Avatar
Aaaaa I see.
Call the dealer and explain the situation if there a reasonable dealer I would think they would take care of the bill and submit it to forest river.
Take pics
Ron
Old 08-13-2012, 10:19 AM   #6
Even though you can't test the tire pressure in that tire, let me suggest this:
1 Check the tire for proper pressure with a hammer. Crawl under where you can hit both tires, the good tire first, and get a feel for the hammer's rebound on that good one.
2 Go to the suspect tire and hit it with the same stroke. If the rebound is the same as the known good tire it means that it is holding it's pressure. Truckers use this method all the time.
3 If good, take it to the dealer.
this is what I would do.
Lostdog
Old 08-16-2012, 07:05 AM   #7
copsuno's Avatar
Lost Dog is right, use this method all time while traveling. Works very well.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 09-07-2012, 11:18 PM   #8
awwall's Avatar
Update: Ordered a set of Borg stems and tire dealer installed all 4 for $53.00. Like to have fell over. Only charged 1 hour labor.
Peace of mind: Priceless
FROG Member
Old 10-03-2012, 06:55 AM   #9
It must be viral issue out of Forest River. Brand new Georgetown acquired 8/30/21. My inner dually extender also would not register any pressure nor would it accept air. Valve totally jammed. Rest were fine. I took everyone's advice and did the rubber hammer thing.
They all soulded the same so now I have to drive 75 mile to dealer for extender replacement. What a pain. No Quality Control on this issue at all.
___________________
Alan in Coral Springs
Georgetown XL 378TS 2013
Jayco Greyhawk 31ds 2012
Alan JS is offline   Reply With Quote
Old 10-03-2012, 07:45 AM   #10
2011 Berkshire 390bh
wnytaxman's Avatar
You might want to check into adding a Tire Pressure Monitor System. It will keep you informed of the tire pressure and temp in all your tires including your toad. They're a few hundred dollars, but they can literally be a life saver.
wnytaxman is offline   Reply With Quote
