Old 02-12-2016, 04:26 PM   #1
**WARNING** Propane leak
I want to warn everyone to check the propane connection to the hot water heater. I noticed my propane tank was empty and had it filled. After I opened the valve on the tank I went inside to turn on the hot water heater. A few seconds later my propane detector went off and I heard a boom. When I went outside the door to the inverter was blown open and smoke was pouring out of the hot water heater. I ran to turn off the propane and sent someone for a fire extinguisher. I opened the door panel to the water heater with pliers as it was very hot. There was fire coming from the propane line connection. Before I could put it out with the extinguisher the fire went out due to me turning off the propane tank.
After it cooled I noticed that the connection was barely finger tight. The weird thing is I have used this on several trips already, so I don't know how it became loose. I used liquid thread dope and re-tightened the nut. I used soapy water to check the joint and it was finally sealed.
I learned a few things.. The propane detector works. before starting a device make sure to turn on the propane and let it sit for a bit so you don't create a spark before the detector goes off.
Luckily there was no permanent damage, but this experience made for a very rocky start to out otherwise uneventful trip. You can imagine how this could have been so much worse.
***PLEASE CHECK YOUR PROPANE LINE CONNECTION TO YOUR HOT WATERHEATER ASAP***
Preadus is offline   Reply With Quote
Old 02-12-2016, 07:46 PM   #2
Iggy's Avatar
Was this a new Georgetown?
Old 02-12-2016, 09:24 PM   #3
Yes, Sorry
This was a Georgetown 351 DS 2014 model 10k miles.
Old 02-12-2016, 09:47 PM   #4
Iggy's Avatar
Lucky you were around.
Good preventive measure to check many things on your rig.
It sounds odd that after 2 years it was loose because those fitting don't back off so my guess it was just tight enough to keep from leaking until the other day.
Old 02-12-2016, 10:00 PM   #5
AWF1945's Avatar
I'm no expert... but not sure you should use pipe dope on any propane fittings.. glad nobody was hurt in your experience.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 02-12-2016, 10:07 PM   #6
Yes you should use it this is a pretty good one
http://www.gasoila.com/products/pipe...et-sealer.html
2014 Georgetown XL 378
kgreen is offline   Reply With Quote
Old 02-12-2016, 10:09 PM   #7
Herk7769's Avatar
Teflon pipe dope is made for gas. They make a yellow Teflon tape that is gas rated.
http://www.amazon.com/Oatey-31230-Jo...=gas+pipe+dope
http://www.amazon.com/Oatey-31262-Gr...MPG9793BCV740S
http://www.amazon.com/Slic-Tite-Thre...MPG9793BCV740S
HAM CALLSIGN - KC3FFW
Old 02-12-2016, 10:12 PM   #8
AWF1945's Avatar
Most gas lines are tapered. ? Or use this..
Old 02-12-2016, 10:15 PM   #9
AWF1945's Avatar
Wow! This site moves much faster than me lol... all get the idea...
Old 02-13-2016, 01:27 PM   #10
abjb's Avatar
Almost same thing happened to us in 2012.
New Aug 2012 spent 4 days at a local Corp of Engineers campground.
Took it back the next week for minor warranty work and a refill of the empty propane tank.
Dealer said they ALWAYS leak test twice!
As I was shaking the hose at the tank I said "do they test it while rolling down the road?" He said WOW as he jumped out of the large white cloud .
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
leak, propane
