Old 11-06-2015, 06:37 PM   #11
New:
compman69's Avatar
I have a question. I have 328ts, has utility closet. My uncle had a brand new combo unit that was in his winter home. How does it mount in the closet. I can not find any brackets or mounting hardware online! Because I didn't buy it from CW they told me they couldn't help. Info Much appreciated.
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
compman69 is offline   Reply With Quote
Old 11-06-2015, 07:10 PM   #12
RSchleder's Avatar
When we bought our new Allegro Bus ( Tiffin MH) it was washer/dryer ready and did not have the vent cut into the unit. The vents are cut in when the washer/dryer is installed and is no big deal to add.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 11-06-2015, 07:16 PM   #13
RSchleder's Avatar
Originally Posted by RVnut View Post
Does anyone know how thick the back of the cabinet to the outside of the skin is on the 364?? So a small brain fart.. Bought a 3" hole saw instead of a 4".... I guess I will exchange it on Monday when we pick up our new coach
Have the dealer drill the vent hole (free of course) for you. That's a small "favor" to ask of them since you bought your coach from them!
30 years RV'ing
11 different RV's
Old 11-07-2015, 08:21 AM   #14
If it's a Spendide comb unit they make a bracket to secure the front legs to the bottom of the cabinet,
Home
> RV Appliances
> Washers & Dryers
> Vents, Pans & Stack Kits
> Splendide SecureFit Brackets
Item #:48026Brand:SplendideModel:MK01 Average Rating:
(No reviews)
Be the first to Write a Review.
Quick Overview
Specially designed kit secures the appliance to the vehicle floor to eliminate movement-linked problems like detached or kinked hoses and more.
Price: $13.77 $12.96
You Save: $0.81 (6%)
Qty:
Sign up for price alert
Email to a Friend
You can buy them online at Dyer RV Supplies. You will also find information on installation on the Spendide website and other a parts and accessories.Be sure to install a brace across the top of the unit during travel to keep unit from tipping out.I installed a 2x4 across the top and attached the board to the inside front of cabinet where you have the frame to secure the board.
conddave is offline   Reply With Quote
Old 11-07-2015, 09:21 AM   #15
Ours just sits in place. You can use L brackets to hold it down if you want. Dealer told us that it would rock the coach more if it was tied down. ours is not tied down and we still get a free ride when it starts to spin.... We have gone 330o miles and not had a problem with the unit moving.
If you use your Uncle's unit, get two folks to move it, remove the cabinet doors, you may also to remove the fridge doors to get the unit down hall. Also measure before bringing it in, make certain it will fit.
happywhencamping is offline   Reply With Quote
Old 02-09-2016, 08:39 AM   #16
RVnut's Avatar
Well after a lot of back and forth with the factory I found out that the sticker marking where to drill the 4" hole was miss located by 10 inches.. I am glad I measured the washer/ dryer first and then asked what was going on.. So the unit is all hooked up except the vent.. I have tried to hook up a piece of flexible tubing since I did not think a solid hook up of the vent strait to the unit was a good thing but that looks like my only options.. I have tried to get a flex tube in for vibration purposes but that is impossible.. There is just no room so we will slide in the vent with the 4" sheet metal tube and see what happens.. Other than this problem the install was not bad.. The hole cut in the wall for the water and drain lines was made by a beaver and I was not impressed
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 02-09-2016, 04:56 PM   #17
RVnut's Avatar
Got it all done and buttoned up
Name:	washer dryer installed 007.jpg
ID:	99279   Click image for larger version
Name:	washer dryer installed 008.jpg
ID:	99280   Click image for larger version
Name:	washer dryer installed 009.jpg
364 Georgetown 2016
in Montana
Old 02-09-2016, 07:21 PM   #18
For those of you with washer/dryer is it worth it? Heard mixed reviews...thanks
Looks very nice, glad it worked out!
JLud is offline   Reply With Quote
Old 02-09-2016, 07:34 PM   #19
We have the separate Splendide washer and dryer units. They are great and we would not want to be without them.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-09-2016, 08:21 PM   #20
Sbryant's Avatar
I just have the combo Splendide unit and believe me I would not be without it. If I had room for a stackable I would jump at it but I don't so the combo is the next best thing. I love my combo!
Sbryant is offline   Reply With Quote
