Old 02-10-2016, 09:50 AM   #21
RVnut's Avatar
Well we will see how it works with the grandson in tow.. I am sure it will beat spending half a day at the laundry mat..
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 06-26-2016, 04:54 PM   #22
Do you follow the directions and shut off the water supply after every use?
Rvretired is offline   Reply With Quote
Old 06-26-2016, 05:56 PM   #23
AquaMan's Avatar
I've never touched the water supply, not so I think I could get to mine without removing the unit. Many times when I leave, I will shut off water to camper, but be mindful that the wife hasn't decided to put a load of wash in before you take off for a bit! Happened just yesterday!!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-26-2016, 06:41 PM   #24
Thanks! That's what we thought.
Old 06-26-2016, 10:50 PM   #25
RVnut's Avatar
Thats is the only way we could get to the supply handles is to remove the unit.. That is not happening..But the DW will not give her combo for any reason
364 Georgetown 2016
in Montana
Old 06-27-2016, 02:27 PM   #26
borba's Avatar
Originally Posted by garybakr View Post
RVnut, I have a 2015 378XL, vented washer/dryer were installed at the factory. I can measure the location of vent if you have the same unit. Good luck.
HI I also have a 2015 378xl washer ready I don't have a mark were to make the hole am afraid don't want to cut a trust if you could measure will be very much appreciated thanks
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 06-27-2016, 05:26 PM   #27
This is not model specific, but twice I have cut holes in my camper and found a 120 volt AC wire running through the area. When I cut for my dryer vent, there was no mark. However, I know I was in the same area that the factory cut and probably within an inch or two of the proper location. I carefully cut the inside hole first and found a wire right there. Fortunately, there was enough slack to move it aside. Also, I installed the duct from my microwave to outside so I could exhaust cooking smoke, etc. Again, there was the wire. This one was the one to power the microwave. Again, why did they put it there? Crazy, huh?
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
