A quick question. Has anybody replaced a wall paneling in a GeorgetownXL 378?
I have some water damage on one board that will need to be replaced.
Is it hard to do?
It is on the driver side main slide.
1 4x6 piece of wallboard would do it.
As far as I know that is just a thin piece of wood veneer glued and small stapled to the wall itself. Behind it should be another piece of plywood attached to the aluminum frame and foam walls.
That is the best I can do in describing it.
If you have the same thin wallboard it should be easy to remove the old and add the new.
