Old 06-27-2016, 08:38 AM   #1
Water Dripping From A/C Hose Passenger Side
I sit in the passenger seat in our Georgetown 30x3. The a/c hoses hang down from under the dash and while driving the condensation from the a/c hoses constantly drip on my feet. The driver side does not have this problem. Any suggestions how to correct this?????
chucknviv is offline   Reply With Quote
Old 06-27-2016, 11:39 AM   #2
Is this hose an a/c pressure hose or the evaporator drain hose? If it is the evap drain hose it should drain to the outside of the vehicle. If it is a pressure hose you should have insulation around it to prevent the condensation.
Paul S. is offline   Reply With Quote
Old 06-29-2016, 11:56 AM   #3
Georgia Gets Around
djinfl's Avatar
This was happening in our XL369 DS and I had it addressed as part of warranty work. whatever they did fixed it because no more dripping on my feet! Sorry I can't be more specific - we had taken it to Lazy Days and the service advisor we were working with either quit or got fired during our service visit. So there wasn't a lot of communication going on that day!
2015 Georgetown XL 369
2005 Jetta TDI
djinfl is offline   Reply With Quote
Old 06-29-2016, 05:22 PM   #4
SimoRandy's Avatar
Send a message via AIM to SimoRandy
I had the same problem and it was fixed under warranty. Not sure what was done.
Randy S.
2016 Georgetown XL 369 & 2013 Jeep Wrangler
SimoRandy is offline   Reply With Quote
Old 06-30-2016, 08:49 PM   #5
Mine was doing the same thing. It was the flexible vent hoses that were dripping water from their outside surface due to the cold air inside the air vent line meeting with the humid and warm air of the coach. I wrapped my lines with thin foam and this stopped the condensation collection.
kurtm is offline   Reply With Quote
Old 07-09-2016, 02:57 PM   #6
Thanks to everyone. When I bring it in for other work I will have them look at it.
Old 07-10-2016, 11:21 AM   #7
check your condensate drain line outside by the right front tire. If its not draining or dripping slowly you will need to unplug using a hanger.
jm7445 is offline   Reply With Quote
water
