12-14-2017, 01:54 PM
Water filter
I have a forest river Georgetown looking for a KW1 water filter is there anything else out there I can use besides this model number I can’t find one anywhere other than the Internet
12-14-2017, 02:05 PM
The KW1 is propitiatory to the FR1 housing.
The KW1 elements are expensive and there have been many posts that for the price of the elements, people have replaced the entire filter assembly with something that uses much less expensive and more widely available components.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
12-14-2017, 03:08 PM
Get something similar to this, cheap and it uses standard 10 inch filters less than $7 each. My GT came with this type.
12-14-2017, 10:37 PM
As bubbles mentions....and they are readily available from Menards, Lowes, Home Depot, as well as Amazon, and they all carry a choice of filter inserts to go with them, plus they don't have the history of leaks like the proprietary ones!!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
12-14-2017, 10:59 PM
Thank you
12-14-2017, 11:00 PM
Hello Bubbles,
Do you have the model number of the filter housing that you used/direct replacement of the original housing? Does this housing come in a 1/2" or 3/4" pipe thread?
Tam & Ha from Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
12-14-2017, 11:44 PM
Originally Posted by tamdle
Hello Bubbles,
This is what I'm using. 3/4" fitting. https://www.menards.com/main/plumbin...1215828&ipos=1
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
12-15-2017, 06:40 AM
Hello Bubbles,
My 2012 GT came with this (similar) type and not the KW1 filter type. I'm not sure of thread but if you can pull yours take it to HD/Lowes etc..
12-15-2017, 07:54 AM
Senior Veteran RV Owner
The KW1 is available here....
WaterPur Filters
Art Mullis
12-15-2017, 08:03 AM
Originally Posted by amullis
The OP indicated in post # 1 they were looking for replacement elements somewhere OTHER than the internet.
12-15-2017, 08:09 AM
Good luck with that! I have checked Lowes, Home Depot, ACE Hardware, Wal-Mart, Best Buy, and some local places. Nobody has a "KW1" filter. The only place it shows up is at
WaterPur Filters
Art Mullis
12-15-2017, 08:15 AM
For one who is capable of changing out these single-source filter housings, is there any GOOD reason to not pull it off and replace it with a filter that has widely available replacement cartridges?
I've done LOTS of mods to my boat, and am embarking on improving my TT now.
I'll start a new thread to gather recommended housings so as to not derail the OP's thread.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
12-15-2017, 08:33 AM
WaterPur Filters
Yes they are tough to get locally but they are available other places than waterpur.com.
Here's a Google search that found them at many R/V stores, eBay & Amazon.
Waterpur KW1 Filter Cartridge
12-15-2017, 09:08 AM
I'm gonna guess you come from "up north" due to your login name!
Another option is to go ahead and get one of the aforementioned "whole house" filter housings and don't install it in your rig.
The reason is you still have to drain it and you don't want antifreeze filling it when you winterize.
Many of us trailer and/or coach owners have removed the onboard filter housing and installed hose fittings to the housing. I/we then use the filter inline with the city water hose either when on city water or when filling the fresh water holding tank. This means you can drain the filter each time you are done with it and not worry about that item getting frozen and cracked.
Happy Trails!
Peace!
Dan & Rita D
12-15-2017, 09:31 AM
Originally Posted by SailorSam20500
This is the same one I saw at menards and plan to switch to it come spring time when the trailer comes out of storage. Then there are many more choices of filters to go with it, and at reasonable prices.
12-15-2017, 11:11 AM
Thanks Sam!
12-15-2017, 12:17 PM
I am thinking I will change the whole thing this coming spring..Or maybe just use the Camco on hose filter and just not put a filter in this one.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
12-15-2017, 12:34 PM
Scoundrel
Thats exactly what I did this past summer. When I de-winterize in spring I'll remove the canister entirely and install a bypass fitting.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
12-15-2017, 12:43 PM
Camco hose filter ~ $18 every year.
Whole house filter with hose fittings ~ $25 incl fittings and one filter.
Next year replace cartridge for ~ $7 and the year after etc....
I've been using my whole house filter on a hose fitting for 10 years so
I've saved about $100.
Yes I'm a certified tight wad!
Peace!
Dan & Rita D
12-15-2017, 12:54 PM
Educated thrifty spender and tight wad are two different horses.
Looks like you have a good formula professor.
