Old 03-22-2015, 10:12 AM   #1
Water filter leak...really weird!
Took our 2015 335 to a nearby campground, Stagecoach RV, Branson, MO. to summerize and check everything out before our upcoming trip to Kerrville, TX. I installed a new filter in the whole house filter, put water in the tank and connected to city water. No leaks...yeah!! An hour or so later I heard a loud bang outside, and just assumed in was from somewhere in the park. In a bit, I turned on the faucet and had no water, so I went outside to check it. The bang I heard was the water filter blowing off. Water was gushing everywhere. The canister threads on and I had tightened with the filter wrench. So, I put it back on, this time leaving the filter out. Turned the water on slowly so I could watch it fill, and after it filled, before my eyes, it starts to unscrew until it finally pops off. Did this three or four times, and thinking it was pressure related , I switched to the pump. While this helped it eventually still twisted loose enough to leak badly, but not to the point of coming off. As a temp fix, I left the handle on and used a strap to hold it in place. I have decided to just remove the filter altogether. One less thing to worry about.
Will and Patty
2015 Georgetown 335DSF
2012 GMC Acadia
2014 Harley Davidson Tri-Glide
Will Parish is offline   Reply With Quote
Old 03-22-2015, 10:17 AM   #2
Flybob's Avatar
Did you have a pressure regulator in the line from the public water system?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-22-2015, 10:25 AM   #3
Yes
Will and Patty
2012 GMC Acadia
Old 03-22-2015, 10:29 AM   #4
Ford Idaho's Avatar
Do not waste another second on that thing.
Pull it out and bypass the connection with a 1/2 inch PVC connector.
While at Lowes or home depot buy this.
Shop Whirlpool Valve-In-Head Clear with Sediment Filter at Lowes.com=
Or one like it.
And this or something like it or you can make your own.
Exterior Canister Water Filter Stand - RVWholesalers.com RV Parts and Accessories
Old 03-22-2015, 10:34 AM   #5
SYE
SYE's Avatar
I am guessing that it is the Forest River FR1 canister with a KW1 filter. This has been a common occurrence with many Columbus owners and the locking tabs get broke off of the canister for 1 of 2 reasons. The wrong type of filter was used and allowed you to overtighten the cannister, or when you winterized, you removed the filter and tightened it rp to tight. These are the 2 things that I have seen on many. the FR1 canister only fits 1 filter, the KW-1 and it is around 30 bucks to buy, some have tried to use a Culligan filter in it and broke the canister. I hope this helps
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 03-22-2015, 10:36 AM   #6
dndnva's Avatar
Is the gasket still in the canister? Mine did this once and it was due to the rubber gasket. I hadn't realized it must have fallen out when I was putting the new filter in.
2016 Legacy SR340 KP (340HP, 2500 Allison)
Toad: 2013 Wrangler Unlimited
dndnva is offline   Reply With Quote
Old 03-22-2015, 11:28 AM   #7
Canadian Member
itat's Avatar
Is this the same thing? It's all could find on the Lowes Canada website. Home Depot Canada's website only shows 3/4" and 1" sizes that look exactly like your picture.
AMERICAN VALVE P240 Sch 40 IPS PVC Union | Lowe's Canada
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 03-22-2015, 11:35 AM   #8
Ford Idaho's Avatar
Way more money for that and they are heavy, I would go to the store and look, even some Hardware stores carry what I posted as they are a common item.
Old 03-22-2015, 11:53 AM   #9
Canadian Member
itat's Avatar
Everything is way more money up here!!
It's entirely possible that they have one like your picture in 1/2". Websites for Canadian subsidiaries tend to be far less complete but lots of times we just can't get products available in the U.S. (like the 5" post covers you guys use for sewer hose storage). I just wanted to see if it's the right material and the right pipe thread.
Old 03-22-2015, 12:14 PM   #10
gashog's Avatar
I hear lots of people complaining that these Forest River FR1 canisters with a KW1 filter unscrew due to the tabs being broken off. When I winterized, I removed the KW-1 filter. So it's possible that I might be confronted with the same problem. Question: How tight is too tight and hows does one know that it's not too loose or not too tight?
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
leak, water, water filter
